32mm spindle nut, how much torque?
Old Sep 11, 2005 | 10:04 AM
Pompiuses's Avatar
Default 32mm spindle nut, how much torque?
Since I don't have my Helms laying around:
How much torque must the 32mm spindle nut be torqued with?
I understand it's important for the wheel bearing that this nut is torqued to spec....
Old Sep 11, 2005 | 10:30 AM
db8sirg's Avatar
Default Re: 32mm spindle nut, how much torque? (Pompiuses)
181 Nm
134 ft-lb
Old Sep 11, 2005 | 11:34 AM
B2FiNiTY's Avatar
Remember to properly stake it too.
Old Sep 11, 2005 | 12:16 PM
baonest's Avatar
Default Re: 32mm spindle nut, how much torque? (B2FiNiTY)
i would think tightening it pretty much as hard as you can will be enough torque.
ive done that all a lot of cars ive worked on.
dont think things like that need to be torque.
its kinda like torqing down your valve cover bolts
Old Sep 11, 2005 | 02:11 PM
markpaco's Avatar
Default Re: 32mm spindle nut, how much torque? (baonest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">dont think things like that need to be torque.
its kinda like torqing down your valve cover bolts</TD></TR></TABLE>
importance of valve cover bolt torque=importance spindle nut torque?
You must be good at replacing wheel bearings.
Old Sep 11, 2005 | 03:13 PM
baonest's Avatar
Default Re: 32mm spindle nut, how much torque? (markpaco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markpaco &raquo;</TD></TR><TR><TD CLASS="quote">importance of valve cover bolt torque=importance spindle nut torque?
You must be good at replacing wheel bearings.</TD></TR></TABLE>
sure thing.
Old Sep 11, 2005 | 03:38 PM
Stinkycheezmonky's Avatar
Suspetise...
I'm gonna have to agree with baonest on this one. With the axle in place, that nut is just making sure everything's not falling apart. It's not like you'd want to put additional stress on the bearing beyond keeping it from falling out or something.
Old Sep 11, 2005 | 03:58 PM
R you serious's Avatar
nothing wrong with knowing the proper specs. by the book is a good habit.
Old Sep 11, 2005 | 04:08 PM
.RJ's Avatar
.RJ
Default Re: 32mm spindle nut, how much torque? (R you serious)
Replace it - dont just reuse it and torque it down. I replace mine 2x a year usually.
Old Sep 11, 2005 | 10:52 PM
RedlinedVTEC's Avatar
I do 6-10 of these a week atleast. I always put my aw480q on max power and torque for 5 seconds or so. IMO safe is better than sorry.
Old Sep 12, 2005 | 10:00 AM
p nut's Avatar
Don't know about you guys, but I usually put a little grease on the bottom of the nut(not on the threads), so that I can torque it down more accurately.
Old Sep 12, 2005 | 12:55 PM
igyloo's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">Don't know about you guys, but I usually put a little grease on the bottom of the nut(not on the threads), so that I can torque it down more accurately.</TD></TR></TABLE>
could you clarify this statement?
Old Sep 12, 2005 | 01:11 PM
p nut's Avatar
S2k's have this clicking-problem caused by an improperly torqued spindle nut. The fix was, tightening the nut to 220 lb/ft(not 100% sure of the figure). To make sure that 100% of the proper torque was applied, a little bit of grease was applied to the bottom part of the nut, where it makes contact with the hub. That way, the friction caused by the two parts rubbing together didn't affect the torque application. Hope that makes sense.
Old Sep 12, 2005 | 03:45 PM
enginemaster's Avatar
just impact it on....with a 1/2 impact gun...with about 120 psi air..
Preferio
Mar 2, 2007 03:13 PM
2000GSR
Sep 3, 2004 09:26 AM
GRAVEDIGGER
10
Aug 18, 2003 12:13 PM
capcon83
Mar 31, 2002 03:38 PM
1fastGSR
Oct 1, 2001 04:20 PM
