Any tips for removing Clear coat?
Old Sep 11, 2005 | 09:06 AM
patastinky's Avatar
Default Any tips for removing Clear coat?
Recently purchased a 93 accord. The clear coat is pealing on the hood and roof of the car. What kind of sand paper and techniques do I use to successuflly remove the clear coat so that I can re/clear it
Thanks in advance
Old Sep 11, 2005 | 10:09 AM
patastinky's Avatar
Default Re: Any tips for removing Clear coat? (patastinky)
Big up!
Old Sep 11, 2005 | 10:22 AM
sammysnakes's Avatar
1) sand blaster
2) lighter fluid & a match
3) hydrochloric acid
4) belt sander w/ 80 grit paper.
Old Sep 11, 2005 | 10:38 AM
OEM_ASSASSIN's Avatar
bump for a real way.
My clear is coming off around my antenna due to it being egged.
Old Sep 11, 2005 | 10:47 AM
Special's Avatar
had the same problem on my bmw and i tried sanding, rubbing compound, anything, but no results. I had to end up re painting it.. But now its hella nice
Old Sep 11, 2005 | 10:51 AM
gaber's Avatar
when sanding just the clear you have to be extremely careful not to sand through the color. From what I remember, you dont have to actually completely remove all of the old clear, but wetsanding with 1000 grit sandpaper and a sanding block will probably be your best bet to remove most of the clear and give something for the new clear to stick to.
Old Sep 11, 2005 | 10:55 AM
Squallie's Avatar
Default Re: (fresh_rides)
wetsanding maybe?
Old Sep 15, 2005 | 08:57 AM
patastinky's Avatar
Default Re: (Squallie)
Any other advise?
DOMAN!EJ8
Paint and Body
May 16, 2011 09:54 AM
'00Accordster
Paint and Body
10
Nov 3, 2008 04:56 AM
beoy9
Feb 12, 2007 09:45 AM
