Darn Check Engine light...
Old Sep 11, 2005 | 07:52 AM
krispyaccord's Avatar
Default Darn Check Engine light...
Well the CEL popped on again today...the message I am getting is this:
Code PO1457 "Evap leak near canister"
Does anyone know the approprate steps to take in fixing this problem...also will it hurt my gas mileage and performance...to run it in this condition?
Thanks
Chris
Old Sep 11, 2005 | 08:02 AM
Chiovnidca's Avatar
Default Re: Darn Check Engine light... (krispyaccord)
The first thing I would check would be the canister vent shut valve.
Old Sep 11, 2005 | 08:22 AM
Default Re: Darn Check Engine light... (Chiovnidca)
Thanks for the reply...where is the canister located on a 6th gen? Also how do I check the valve for proper operation? Thanks
Chris
Old Sep 12, 2005 | 05:13 AM
bump
Old Sep 12, 2005 | 09:33 AM
JimBlake's Avatar
EVAP canister is #5, the vent-shut valve (#8) is on the outboard end of the canister. It sits roughly under the left-rear seat.
Make up some jumper wires to power the V-S-valve directly from the battery. When mine went bad it was corroded stuck so it didn't even click.
If that valve is OK, it might be any of those other hoses or components isn't airtight like it should be. Check out this thread, scroll down to my post describing some stuff to check out.
https://honda-tech.com/zero...63913
Old Sep 12, 2005 | 02:07 PM
Thanks Jim, you are my hero!
Chris
Missouri_Civ
Sep 18, 2007 07:40 PM
mikester_91
Jan 11, 2005 05:20 AM
dylokjai
Nov 13, 2004 07:42 PM
