installed my poor mans type r a week ago and no more oil.piston rings?smoking.
Old Sep 10, 2005 | 09:19 PM
aser1z's Avatar
Default installed my poor mans type r a week ago and no more oil.piston rings?smoking.
just a week ago i installed my poor man type r in my eg and already out of oil.when i'm on gear i let of the gas to build up back pressure and then i step on the gas again and it smokes a bit from my exhaust.do you guys think its the piston rings?my plans are to take off the motor and tear it up take the gsr block to the machine shop to check if any of the cylinders are offset and if/not get new rings or new block.need help.please.
Old Sep 10, 2005 | 09:35 PM
aser1z's Avatar
Default Re: installed my poor mans type r a week ago and no more oil.piston rings?smoking. (aser1z)
help please
Old Sep 10, 2005 | 09:41 PM
sicky's Avatar
grammer nawzi
In 16 mins you expect there to be an answer? Damn, be patient. People these days
Old Sep 10, 2005 | 09:57 PM
BoOstedEM1's Avatar
If those are your plans what do you need help with..they will help you.
Old Sep 13, 2005 | 03:23 PM
Circuit Star-29's Avatar
Did you align the rings correctly?
Old Sep 14, 2005 | 10:29 AM
aser1z's Avatar
Default Re: installed my poor mans type r a week ago and no more oil.piston rings?smoking. (C-speed Ricer)
im pretty sure i did.well i just took off the pistons and they have carbon but are wet a bit i think with oil.on two of the pistons there are also burns on the side of them right to the first piston rings.can this mean they are burned?
Old Sep 14, 2005 | 10:37 AM
johniericeboy's Avatar
if you dont have an oil leak then it can only be rings to use that much oil in a week
if you do have a leak then it might be valve stem seals but you would still have to have an oil slick on your driveway for this much oil to be used
Old Sep 14, 2005 | 10:53 AM
b204dr's Avatar
is it burning the oil or leaking- ? even if one ring was bad it would last a little longer that this - all four would need to be seated incorrectly
Old Sep 14, 2005 | 11:12 AM
Suck my DX's Avatar
Default Re: installed my poor mans type r a week ago and no more oil.piston rings?smoking. (b204dr)
if the ring are that bad to burn away all of ur oil within a week it will smoke alot not just a little...it will literally be pouring out smoke...
Old Sep 14, 2005 | 11:27 AM
Default Re: installed my poor mans type r a week ago and no more oil.piston rings?smoking. (Suck my DX)
Sounds like your ring packs were aligned. They're not supposed to be....If you burnt the side of the piston, you may have scared your cyl wall.
Old Sep 14, 2005 | 03:52 PM
aser1z's Avatar
latest from the machine shop,
the cylinders are off spec, only one cylinder is good.the cylinder walls also had some small scratches i could feel with my finger nail.now none of my friends or connects have gsr bottom ends.so up for grabs right now are a second gen sirII block includes everything except clutch and flywheel, my gsr block complete with no rods or pistons and will need to be bored includes block guard no clutch or flywheel, another gsr block legit will also have to bore one cylinder is off spec.
so throw me offers or trades for legit standard gsr blocks 81mm or just a legit gsr block housing standard size.
Modified by aser1z at 5:04 PM 9/14/2005
jdmej814
Jan 29, 2009 10:19 AM
allmotorgsrekk
Aug 6, 2006 08:11 AM
bboyoxygen
11
Nov 2, 2004 09:55 PM
EFb18b
Feb 24, 2004 02:16 PM
Islander
Oct 11, 2002 02:45 AM
