Cam seal question
I noticed on my girlfriends car her cam seal was leaking, so i looked further and noticed that the seal was sticking out, roughly, 1/16 of an inch from the motor.
So, my question is....should I replace it, or could i simply tap it back in?
And if i can't tap it back in, tell me why if you can
this is great i actually just started experiencing th same prob last night ...is it possible to sneak it out by just removing the last bearing cap a bit...or do i have to remove the valve cover also....does anyone have the exact procedure ..ive never had to replace a cam seal in a b-motor ..maybe its just me but i havent ever seen one leak ...would appreciate..the correct procedure and/or the express/correct version...thanks guys
yea I was kinda figuring that i could get it out from the outside, because it's sticking out a tad. I could probably get a screwdriver or two behind the gap and pry it out. But taking off the valve cover isn't hard at all. And after the valve cover, it's just removing the cam holder plate bolts on the exhaust cam only. They are 12 mm bolts on the inner holders and 10 mm on the outer holders.
here's a good link i've found
http://www.team-integra.net/se...D=576
read all the pages and it'll sound easy as pie.
i dont have anything in the way of my front cam like the gsr picture..the seal is wide open...instead of removing all of the bearing caps/plate...could i get away with removing just the cap over the seal and sneak it out and in or should i still take out all of them and pry up the cam a little?.. i dont wanna go thru more hassle than i need to if someone has done this in an easier way... i work for volkswagen and the cam seals are a bitch on those so i was just wondering if there is a still effective shortcut?
Remove the valve cover, then remove the cap on the left that covers the cam seal..
r/r cam seal..
replace cap. torque to spec.
then install valve cover, torque to 9ft.lbs
r/r cam seal..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JH4DC4-2GSR »</TD></TR><TR><TD CLASS="quote">Remove the valve cover, then remove the cap on the left that covers the cam seal..
r/r cam seal..
then install valve cover, torque to 9ft.lbs</TD></TR></TABLE>
thank you sir
r/r cam seal..
thank you sir
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAguyLS »</TD></TR><TR><TD CLASS="quote">thanks kendall
btw why do you have a blues clues avatar?
i've always wondered why</TD></TR></TABLE>
Kinda fruity if u ask me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crucial-vtec »</TD></TR><TR><TD CLASS="quote">
Kinda fruity if u ask me...</TD></TR></TABLE>
yep and we didnt ask...lol
Look at his name, Kendall AKA = KEN DOLL
B16B Four Door
Oct 27, 2011 05:45 PM
