jdm access 3rd brakelight question?
Old Sep 10, 2005 | 06:20 PM
momstaxi's Avatar
Default jdm access 3rd brakelight question?
so i just recieved my honda access high mount brakelight today, (the one that lights up green and says "accord") and when i was examining the light bulb and socket and the wiring that was cut i noticed that after the plug it comes out with 4 wires, 2pwr and 2gnd...this is the first time i noticed this, and now that i think about it i ve seen an ef version and it stays on constantly, so i wondering if anyone knows how the proper way to wire it up would be?
something like a taillight where it is on then gets brighter when the brakes are applied or maybe is on during w/o headlights on but turns off when the lights are turned on so it can be used as a brakelight? im not sure but if anyone knows or could shed any insight it would be appreciated..
Old Sep 10, 2005 | 06:22 PM
momstaxi's Avatar
Default Re: jdm access 3rd brakelight question? (momstaxi)
also i just looked and it appears to be a single filament bulb even though the bulb sockets are completley different....(my old usdm one, and the jdm one)
Old Sep 10, 2005 | 07:23 PM
gianinline's Avatar
...have you thought about using 2 wires as 1... conecting the 2 red ones together and the 2 black ones together too... and then... connecting to the ones you need to connect...
...know what i mean?
....well... i would try that...
Old Sep 10, 2005 | 07:42 PM
momstaxi's Avatar
Default Re: (gianinline)
yeah, i just plugged it in. it works fine as a brakelight, i am just wondering where the other set of pwr and gnds would normally go on a japanese car...
Old Sep 11, 2005 | 02:15 PM
momstaxi's Avatar
Default Re: (momstaxi)
anyone else?
Old Sep 11, 2005 | 02:36 PM
ricepicker's Avatar
I imagine it would go through relays, not exactly sure how though.
Old Sep 11, 2005 | 03:16 PM
JohnnyTequila's Avatar
Default Re: (ricepicker)
you actually spent money on a brake light that says accord?
you could have made your own template that says that and put it in front of your stock one....
Old Sep 11, 2005 | 03:19 PM
ricepicker's Avatar
Default Re: (JohnnyTequila)
Yeah, you can also buy replica black housing headlights. But what's the fun in that?
Old Sep 11, 2005 | 03:26 PM
momstaxi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyTequila &raquo;</TD></TR><TR><TD CLASS="quote">you actually spent money on a brake light that says accord?
ghey
whats the fun in faking the funk?
Old Sep 11, 2005 | 05:45 PM
JDM.Accord's Avatar
Yes but its not JDM
They're one of the more rare parts for the Accord as well, and cool as hell (my avatar)
Okay here's what I did with mine.
I bought the entire 3rd brake light assembly which also happened to be a different color interior then mine. The brake light housing comes apart quite easily (just several screws) and there is a plate in there that has the 'Accord' graphic on it. That just pops out.
What I did is take my USDM housing and removed the red USDM plate and placed the green JDM 'Accord' plate in the USDM housing. That way you don't have to mess with relays and bulbs and connections, or in my case, painting the housing. Its really simple and mine works awesome.
Its really bright and I get compliments on it constantly. No po-po problems either
Old Sep 11, 2005 | 05:57 PM
momstaxi's Avatar
Default Re: (JDM.Accord)
yes, i also took mine apart as it came in a dark grey interior but mine is the light blue...so i swapped them..
but anyways i think i figured it out...i remember seeing an auction for an ef civic one and it came with a relay or something that steped down the voltage from 12v to 3v. so now maybe im thinking that when the headlights are on its getting 3volts so it is lit up dimly but when the brakes are applied it gets the 12v from the other set of wires making it brighter...
does that make scense to anyone and would it work?
Old Sep 11, 2005 | 08:14 PM
JDM.Accord's Avatar
Its a hella lot easier to just put your usdm brake light in there just like you had it only with the jdm plate. Believe me, I've been there
michael_c
Jan 10, 2008 11:26 AM
[Ennis_D]
Jan 11, 2005 06:50 AM
messeduprex
Nov 27, 2004 10:36 AM
stock92prelude
Aug 30, 2003 09:06 AM
thaiphob
25
Sep 11, 2002 07:14 AM
