b16 swap into 96 civic.......wiring help needed
What wiring harness should i use that would be the easiest. I have 2 99-00 harness both auto and i cant get them to work. I also have a obd2 p2t ecu and a obd1 p30 that came with the motor. What would be the best way to have the engine wired up. I have the motor in and everything ready to go but the harness and ecu.
You should use the 96 wire harness that comes with your car. Just use your stock computer to run the car until you get a obd2 to obd1 converter harness. Do a search because there is a how to on ek swaps..
the car was a shell i am rebuilding the whole thing. so i should get a stock 96 ex harness and run the p30?
ITR.#1446
Sep 10, 2005 04:43 PM
NEED HELP GETTING A HARNESS FOR MY 96 DOING A B16 SWAP DOES ANYONE CUSTOM MAKE HARNESSES PREFFERABLY
turboed4life
14
Mar 27, 2004 07:40 AM
