Amp Ground Wire
Old Sep 10, 2005 | 04:20 PM
J_Lude07's Avatar
Default Amp Ground Wire
I was wondering where everyone wit a 94-97 accord has there ground wire from there amp hooked up?...i had a battery in the back and i just hooked it up to the battery but i decided to take the battery out so i could have more room and now my amp isnt turning on...one of my friends said my ground wire hook up isnt good...
Old Sep 10, 2005 | 04:26 PM
-RedneckDave-'s Avatar
Working
Default Re: Amp Ground Wire (J_Lude07)
All you need is a good chassis ground. Just use an existing bolt like the ones for the back seat hing or something similar.
Old Sep 10, 2005 | 05:13 PM
Alibi86's Avatar
Well. i mounted my amp under the drivers seat. So i grounded mine in the same place as the Seat Belt Indicator is gorunded. Its under a small flap of carpet under the seat towards the front. Just make sure u scrape away any paint to insure a good ground.
Old Sep 10, 2005 | 06:16 PM
sj993's Avatar
Default Re: (Alibi86)
I mounted mine on behind the back seat and grounded it under the back seat. Shorter ground wire the better.
Old Sep 11, 2005 | 06:13 AM
J_Lude07's Avatar
Default Re:
Alright thanks....i might be thumping by tonight...do all alpine cd players have the same wiring harness plug in?
Arthas
Audio / Security / Video
12
Apr 9, 2012 07:36 PM
wegotmorrison
Jun 16, 2010 10:47 PM
Quetzolcotl
Feb 7, 2004 07:08 PM
97gSrkId88
Mar 8, 2003 01:56 AM
ijcameron
Mar 7, 2002 01:48 PM
