Piston Speed
Old Feb 27, 2002 | 08:49 AM
Elex's Avatar
Default Piston Speed
Okay i think my math is right if the piston speed in a motor at 9800 rpms is 5,917.67 feet per minute would that be bad? i compared it to a B16 and the B16 would need to be at 10,373rpms just trying to see if my math is right and is the piston speed to high in that motor.
Old Feb 27, 2002 | 10:58 AM
Mikey3000's Avatar
Default Re: Piston Speed (BSeriesMadness)
use (.166 X Stroke (in.) X rpm X 3.28) / 60 as the equation. you shouldn't use feet/minute seeing as that isn't using Si units. i have no concept of feet/minute. this equation i put above is meters/second.
Old Feb 27, 2002 | 11:02 AM
Elex's Avatar
Default Re: Piston Speed (H22Turbo)
okay i did that and it comes out to 321.93
Old Feb 27, 2002 | 11:11 AM
Mikey3000's Avatar
damn, that's pretty damn fast. i calculated what the piston speed would be on a stroked to hell H22 (stroked motors have higher piston speeds) and it only came to 292 m/s. a stock H22 has 259 m/s and that thing has a shitty 1.57:1 rod/stroke ratio. oh but then again you're doing it at 9800 rpm. i forgot about that. i calculated mine @ 8000 rpm. yeah i guess that sounds pretty good.
[Modified by H22Turbo, 3:14 PM 2/27/2002]
[Modified by H22Turbo, 3:15 PM 2/27/2002]
Old Feb 27, 2002 | 11:14 AM
Elex's Avatar
Thanks for the help!
dart2.2
Jan 16, 2007 11:26 AM
Combustion Contraption
Mar 22, 2005 05:00 PM
91integraLSVTEC
Feb 15, 2004 03:53 PM
Zeus Zore
Oct 4, 2002 07:50 AM
HXMan
Sep 19, 2001 06:48 AM
