starting problem
Old Sep 10, 2005 | 03:06 PM
seanclark's Avatar
Default starting problem
ok first my setup
i have a 92 civic with a d16z6 engine, td04h15g turbo, 450cc injectors,jrc intercooler, all tuned with uberdata
i went to my car a couple of days ago tryed to start it and just heard a clunk, automatically i thought to myself it was the start motor, so i replaced that tried again with exactly the same result, i checked the battery that is fine, then i tryed turbing the engine by hand and that was fine so not a seized engine.
can anyone think of anything that may be causing this ? im a bit lost
also if i turn the engine by hand then try and start it it will turn a couple fo times then make the same clunk noise
Old Sep 10, 2005 | 03:21 PM
NJcoupe's Avatar
Stock motor? Possible internal engine damage. Or possible clutch failure?
Old Sep 10, 2005 | 03:30 PM
slambedcivic's Avatar
Default Re: (RHDej2.)
clutch fingers might be broken, sounds like a possible bent rod. check your timing belt as well
seanclark's Avatar
yeh stock internals running at 9psi on a slightly dubious tune done by myself (it was running quite on the rich side, i think its time to rip the motor out and to forged internals !
Old Sep 10, 2005 | 03:34 PM
Default Re: (seanclark)
thats not a must right now. find out what the problem is now.
Old Sep 10, 2005 | 03:46 PM
macDelli's Avatar
Default Re: (slambedcivic)
you might even want to do a general tune up i mean it wouldnt hurt...
Old Sep 11, 2005 | 08:11 AM
NJcoupe's Avatar
Change your cap and rotor.
Old Sep 18, 2005 | 06:34 PM
seanclark's Avatar
Default Re: starting problem (seanclark)
ended up being a starter earth problem, easily sorted, cheers for the help guys
wid2001
Jul 14, 2016 12:39 PM
feret
14
Nov 21, 2013 08:36 AM
trololog
Jun 19, 2013 07:03 PM
jeffrey.t.dellosa
12
May 2, 2007 07:44 AM
heeltoer
Jan 4, 2005 07:11 AM
