How to fix sticking Ebrake?
Old Sep 10, 2005 | 02:29 PM
Mag00n's Avatar
Default How to fix sticking Ebrake?
I have rear discs on my crx. The ebrake cable is sticking on the driver side rear. I am 100% positive without a doubt that it is the cable and not the caliper/rotor/pad.
How do i go about fixing this? Do I need a new cable? What would cause it to stick?
It takes about 20minutes of sitting once I disengage the ebrake in the car for it to release on the wheel.....
Old Sep 10, 2005 | 03:39 PM
mrtoastyjr's Avatar
Default Re: How to fix sticking Ebrake? (Mag00n)
make sure the spring on the caliper is still good(ive been bitten by that one once) and other than that i would say you need a new cable.
i see you live in NY, and the most likely cause is corrosion, with all the salt in the winter time. good luck
Old Sep 10, 2005 | 06:57 PM
Crx Jimmy's Avatar
i had a problem like that once it was the caliper, just remove the cable from the caliper and see if you can push/pull it freely if its binding get a new cable if not its prob the caliper
Old Sep 10, 2005 | 07:15 PM
SIRX's Avatar
rust is not your friend. most cars over 15 years old the e-brake hasn't been touched in 5-7 years (nobody ever uses them) so you learn that if you do use the e-brake the rear brakes will not disengage. lucky for you that only one side is sticking. change it
Old Sep 12, 2005 | 09:22 AM
Turbo_Mike's Avatar
Default Re: How to fix sticking Ebrake? (SIRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX &raquo;</TD></TR><TR><TD CLASS="quote"> lucky for you that only one side is sticking. change it</TD></TR></TABLE>
king_mo
Mar 4, 2009 09:46 AM
coupe_hybrid
May 20, 2006 09:31 AM
FernEF
Feb 13, 2006 07:42 PM
b16_madman
Apr 7, 2005 11:05 PM
