Finished Changing timing belt and now CAR won't START??
Old Sep 10, 2005 | 01:14 PM
MachAF's Avatar
Default Finished Changing timing belt and now CAR won't START??
Ok so I changed my timing belt and water pump. Made sure the timing marks were lined up. Put everything back together.
I turned the car over without the plugs in and i forgot to pull the ecu fuse. So might be flooded?
I put the plugs in and tired to start it. No luck. Pulled the plugs, they are wet.
Let everything sit for 30-45 mintues incase it was flooded. Tried again. No start. It almost wanted to start, it sputtered a lil bit.
So then i check the plugs and each is sparking.
Any ideas? Is my timing off or what? I have no idea.
Thanks
****- I think i forgot to make sure the t-belt drive gear was aligned with the mark. I just made sure the cam gears were lined up. Could this be why???
Old Sep 10, 2005 | 01:41 PM
drumking15's Avatar
all three marks need to be aligned...the 2 cam gears and the main crank pulley...hopefully you were smart and did a couple cranks of the MCP by hand to make sure it wasnt interfering...or you could have just bent some valves
Old Sep 10, 2005 | 01:59 PM
MachAF's Avatar
Default Re: (drumking15)
yes I made sure valves were not hitting
Old Sep 10, 2005 | 02:10 PM
vtec18l's Avatar
Default Re: (MachAF)
we had teh same problem...make sure its TDC and also check the tensioner, make sure the belt is hella tight =x if all else fails, have someone time it =p
Old Sep 10, 2005 | 04:02 PM
MachAF's Avatar
Default Re: (vtec18l)
That was the prob..
Crankshaft pulley deal wasn't at TDC.
STarted like a champ.
Jdbdkid93
15
Jan 25, 2021 05:20 PM
thekeysarebroke
15
Oct 1, 2012 05:35 AM
ftrms
Nov 19, 2008 06:20 PM
specv5150
11
Oct 7, 2004 02:39 PM
GroundZer0 336
13
May 24, 2004 09:27 PM
