200$ crx wont start any ideas welcome
Old Sep 10, 2005 | 12:37 PM
sickerhatch's Avatar
Default 200$ crx wont start any ideas welcome
ok i bought an 88 crx si for 200$ not running so far ive replaced the dizzy the main relay clickes and im geting fuel to the rail but NO SPARK.aNY IDEAS WHY THE PLUGS WOULD NOT FIRE? thanks
Old Sep 10, 2005 | 12:40 PM
2fast4udude's Avatar
Default Re: 200$ crx wont start any ideas welcome (sickerhatch)
well, if the plugs wont fire and the dizzy's been replaced, try replacing the spark plug wires and the plugs as well.
Old Sep 10, 2005 | 12:43 PM
mycrx7's Avatar
Default Re: 200$ crx wont start any ideas welcome (2fast4udude)
my cars doing the same **** right now, stock ls turbo but wont even fuckn start with a stock pm6 and injectors.
Old Sep 10, 2005 | 12:47 PM
Default Re: 200$ crx wont start any ideas welcome (mycrx7)
ive trid diffrent plugs and wires thats not it its getten no spark at all. Should the light on the ecu blink at all when the key is turned on?Im thinken the ecu is dead.
Old Sep 10, 2005 | 12:50 PM
is the check engine light on? is the ECU throwing any codes?
Old Sep 10, 2005 | 04:36 PM
b18cEF9's Avatar
maybe theres a killer after you
Old Sep 10, 2005 | 05:04 PM
EFb18b's Avatar
the CEL should come on when the key is first turned the "ON" position for 5 seconds or so then go out. If you are not getting a CEL at all a wire at the ecu harness to the dash is either cut or disconnected.
as for the $200 crx not starting. You're not giving enough info. Is it turning over at all? do all of the lights on the dash come on when the key is turned on? have you checked for vacuum leaks? Have you traced out any of the wires going to the distributor? if so, where do they go?
a helms manual would be great for you right now
Old Sep 10, 2005 | 05:31 PM
ryan89crx's Avatar
i have a great idea...ill give you $200 for it and you wont have to worry about it anymore
Old Sep 10, 2005 | 06:09 PM
EFb18b's Avatar
Default Re: (ryan89crx)
Hell, I bought a crx si one time for $300 with the head totally taken apart, all the vacuum lines were in a box, and the throttle body was sitting in the passenger's side floor board. I sprayed choke cleaner on EVERYTHING and put it all back together with a helms and it started right up with a fresh battery.
Then I turned around and sold it for a $1000
Old Sep 10, 2005 | 06:14 PM
ef8 h0!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">i have a great idea...ill give you $200 for it and you wont have to worry about it anymore </TD></TR></TABLE>
x2
tr3nt133
Nov 5, 2014 03:50 PM
dwerpk
Dec 29, 2006 10:13 AM
lifesk8err
Apr 11, 2005 12:15 PM
RotiEatter
Nov 22, 2004 04:47 PM
mockujin
Nov 13, 2002 07:03 PM
