suggestions on axle nut removal?
I've been trying to get my axle nuts off that are stuck on. used a 500tq impact 1000 tq impact, hand impact(one where you hit it with a sledge hammer), torching it still nothing anyone have anything else i can try
just get a breaker bar and stand on the bitch.....
when i was trying to get my motor out of its suspension drop we had to use 3 peices of rebar and me standing on the breaker bar to get it....
the bar is like 3 or 4ft long though....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq »</TD></TR><TR><TD CLASS="quote">I have a Stanley socket welded to the bent pipe. I can lenghten it as much I need. And it works.</TD></TR></TABLE>
breaker bar, 6' cheater pipe, and a big friend usually works
holy ****.....you should get the breaker bar that has the socket connector as a big body that slides up and down the pole, its like a 3/4inch diameter metal bar with the connector that can move up and down on it...
practically unbreakable....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveobb4 »</TD></TR><TR><TD CLASS="quote">Did you rememer to pry up the indented part on the nut? I broke mine lose while the car was on the ground still. Good luck</TD></TR></TABLE>
^ what he said. Not prying up that indentation will make it much harder to remove.
yes i'm turning it in the right direction and i soaked it in wd40 pb blaster. you nameit. i think i'm going to try to cut the nut off to get the axle out cuz i got new ones and these are blown
broke a few breaker bars on mine too, good thing they got lifetime warrantys right!!
did u pry the axle nut back from inside the wedge that locks it in? I didnt think my impact gun waz working either, till a good 15 or so minutes sitting there on full speed spraying some blaster (i find it works better then wd40, yellow can) finally broke free. good luck
I hate those ******* things. I broke two craftsman breaker bars trying to get one off. I took a die grinder to it, and beat the **** out of it. Then it came off with my 600ft-lb impact gun.
i must agree. those suck. i actually broke the socket... cracked right down the side. ended up getting it off with an impact gun. seriously just sit there with an impact gun for 20min it's bound to come off... eventually
can someone please help me, so far ive used most breaker bars except for a snapon brand one, but theyve all snapped, ive sprayed the bolt numerous times for liek 10 minutes straight and still no luck, i could get a 50 psi air compresser with an impact gun, does it matter that the tank is 50 psi? will it give out at least 180 pounds of torque if i have a good gun? someone please help me because ive been sitting here for almost a week breaking tools...and i cant get my car to a shop because it does not drive right now
yeh okay, i was told craftsman was good, so i go ahead and get all their **** for this, and its all broken, the craftsman 18 inch breaker bar broke from one push down on it, snapped right at the part where it connects to the socket....bullshit...so will this 50psi tank work with a good 300torque gun?
Your souposed to be turning it in the left direction. JK
put a breaker bar onit at the 3 oclock direction so that your actually lifting on the bar and not pushing down. You can lift more than you can push down. You can only push down your weight. I have never had an axle nut I could get off this way with a autozone special breaker bar you know the 15.00 dollar one.
