VSS Required
Old Sep 10, 2005 | 12:21 PM
bcborn's Avatar
Default VSS Required
I'm installing a JDM SiR cluster in my 1991 CRX. The SiR cluster uses a electronic VSS, where as my CRX uses a cable.
What model and year of vehicle do I need to get the VSS from to work with the OEM 1991 "D" Series tranny (L3 cable type)
Old Sep 10, 2005 | 01:36 PM
hizroyalty's Avatar
Default Re: VSS Required (Mysterious Bob)
99 si
Old Sep 10, 2005 | 07:36 PM
bcborn's Avatar
Default Re: VSS Required (hizroyalty)
Is that the same as 96 - 00, or only the 99 Si.
Old Sep 10, 2005 | 07:41 PM
Fobtions's Avatar
you can use any electronic vss.
b series, d series., H series
Old Sep 10, 2005 | 07:51 PM
bcborn's Avatar
Default Re: VSS Required (Fobtions)
The 92 -95 unit looks totally different than the 96 -00 unit. I do not even know if mounting is the same. the 92-95 loks like a 2 piece unit where the 96+ is one piece.
Old Sep 11, 2005 | 10:38 AM
bcborn's Avatar
The VSS needs to fit a 1988-1991 D Series cable tranny. Currently their is a one bolt clip that holds the speedo cable gear unit to the transmission case.
Modified by Mysterious Bob at 10:09 PM 9/11/2005
Old Sep 12, 2005 | 10:03 PM
Mista Bone's Avatar
D Tranny Guru
see me
Old Sep 15, 2005 | 05:31 PM
R6Boy69's Avatar
i got one that will work for you it comes with the connector too... 45 shipped
Old Sep 15, 2005 | 05:36 PM
Mr Synister's Avatar
Default Re: VSS Required (R6)
92+ civic vss or 94+ integra. they work on both d and b trannys
mugenwannabe
Sep 21, 2006 11:14 AM
crexer
Nov 4, 2005 03:47 PM
crexer
Jan 29, 2005 08:28 PM
johnzm
Aug 30, 2002 09:32 PM
