Problems with headlights, extended them to hide in fender, now the dont work!
For some reason they dont work now. Like the only side that gets power is the city lights which i wired in with the turn signals so they come on with the first click. Now for some reason though even in the off position they still get power, well not both city lights but just the drivers side one. Anyone have any idea what the hell is going on? I checked the ground on each harness, and they are good to go.
Up wondering, if this has happened to anyone else? Or if anyone has the diagrams for the passenger and drivers side Headlight harness. HELP!
Sounds like you wired something wrong, Id take it back apart and double check all your connections and make sure you have it all pined out correctly again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">Sounds like you wired something wrong, Id take it back apart and double check all your connections and make sure you have it all pined out correctly again.</TD></TR></TABLE>
True, With that said does anyone have the wiring diagram from a HELMS manual for the drivers side and Passengers side Headlight Harness? If Not could you scan it up for me? PLZ? Thanks
Yea i checked the ones under the dash, nothing. Cause like i wired it up and then plugged the battery back up. And for some reason just the drivers side city light was on, not even the passenger side was on. And then i tried to see if the switch inside the cabin would work, with no luck. For some reason the red wire to the city lights was 'hot'. It was giving power while the other side wasnt, I have no clue why.
<FONT SIZE="5">Anyone Have the Pages i can use to fix this? Like the diagrams needed for the right and left side headlight harnesses that originally run in the engine bay? Scanned up?? HELP!</FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soda Popinski »</TD></TR><TR><TD CLASS="quote"><FONT SIZE="5">Anyone Have the Pages i can use to fix this? Like the diagrams needed for the right and left side headlight harnesses that originally run in the engine bay? Scanned up?? HELP!</FONT></TD></TR></TABLE>
You can find what you need at CSi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer »</TD></TR><TR><TD CLASS="quote">
Sorry to sound dumb here, but do you mean Club SI.com?
If so isnt that for just 99si-00? I have a 93EG.
<FONT SIZE="5">Also can anyone at least tell me the pages? I can find my way to a Helms at my friends mechanic shop and scan it up, meaning i steal it from him and give it back... LOL But could anyone tell em what pages they are?
</FONT>
</FONT>
i had the same problem man, i figured it out though. there is that little box that is white. its hard to explain, it needs to be grounded. thats why my headlights weren't working.
Nino_eg6
Jun 13, 2008 01:05 AM
freeflyinrider
Dec 5, 2007 07:04 PM
midnightsilence
Aug 14, 2004 10:09 PM
speedycivicgurl
Aug 13, 2004 07:21 PM
