Check Engine.
Old Sep 10, 2005 | 10:43 AM
Connal's Avatar
Default Check Engine.
On my 90 accord LX coupe last night my check engine light went on. No big deal I can just go home and use my repair manual to find where I can use a paper clip and check the code right? Wrong. I have a good ideq where it is all at. I have pulled back the carpet in the floor and found the whole ecu. I can't find the little jumper wire though. Is it under the metal plate covering the whole mess up? Or is it just off to the side tucked under the edge? Any help would be appriciated.
Old Sep 10, 2005 | 10:45 AM
ricepicker's Avatar
Default Re: Check Engine. (Connal)
check more up by the glove box.
Old Sep 10, 2005 | 11:12 AM
Connal's Avatar
Thanx ricepicker, i'm gonna run out and check.
Old Sep 10, 2005 | 12:05 PM
Connal's Avatar
I've been busting my butt trying to find it but I still can't. There is a big metal plate covering the main unit. Up above it? There is nothing more than where it looks that the dash is connected to the firewall. Is it plugged into something? Tucked behind something? I'm racking my brain tring to figure this out.
Old Sep 10, 2005 | 12:09 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Connal &raquo;</TD></TR><TR><TD CLASS="quote">On my 90 accord
I can't find the little jumper wire though. </TD></TR></TABLE>
The 1990 Accord doesn't have a service check connector, they came with an led in the ecu. Peel back the carpet, turn on the key and count the blinks.
Old Sep 10, 2005 | 01:20 PM
Connal's Avatar
Default Re: Check Engine. (Chiovnidca)
So do I need to take off the metal plate??
Old Sep 10, 2005 | 01:32 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Connal &raquo;</TD></TR><TR><TD CLASS="quote">So do I need to take off the metal plate??</TD></TR></TABLE>
Nope, should be a hole in it to look through.
Old Sep 10, 2005 | 03:20 PM
deserthonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
The 1990 Accord doesn't have a service check connector, they came with an led in the ecu. Peel back the carpet, turn on the key and count the blinks. </TD></TR></TABLE>
you are totally wrong. Chio...........the 90 accord has a plug it is blue 2 wires going to it ,,some times it is tucked behind the right kick panel and it is taped with some blue tape..it could be a pain on the butt to locate but trust me it is there..
Old Sep 10, 2005 | 05:04 PM
Connal's Avatar
Hey, I figured it out and got error code 7. Now I just need to find a new TPS. Really appriciate the help.
Old Sep 10, 2005 | 05:19 PM
Chiovnidca's Avatar
Default Re: Check Engine. (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">you are totally wrong. Chio...........the 90 accord has a plug it is blue 2 wires going to it ,,some times it is tucked behind the right kick panel and it is taped with some blue tape..it could be a pain on the butt to locate but trust me it is there..</TD></TR></TABLE>
Well, if they do I never had a need to look for it. I always read the blinks off the led on the ecu on 1990 models. The led disappeared on the 1991 model so you have to use the service check connector.
sc95delsol
14
Oct 24, 2007 04:38 PM
h22__guy
Dec 18, 2006 12:40 PM
01-0720
Feb 19, 2006 11:11 AM
OshkyCiv23
Oct 23, 2005 07:15 AM
osuperjohno
Jul 28, 2005 08:17 AM
