Just picked up a 88 HF CRX, DOHC ZC Swap Question??
Old Sep 10, 2005 | 10:16 AM
The DX Rex's Avatar
Default Just picked up a 88 HF CRX, DOHC ZC Swap Question??
i just picked up a 1988 CRX HF.
now i also just bought a complete OBD0 JDM DOHC ZC Motor/ W/ZC L3 Tranny
my question is:
1. what axles do i use? do i need to change hubs? i've heard the HF used different axles and the hubs are different from other EFs, is that true?
Old Sep 10, 2005 | 10:20 AM
Jonny Black's Avatar
Si hubs and Si axles
Old Sep 10, 2005 | 10:26 AM
The DX Rex's Avatar
Default Re: (Jonny Black)
so i have to use Si Hubs/Axles, DX wouldnt work or anything other than HF ?
Old Sep 10, 2005 | 10:41 AM
Default Re: (The HF Rex)
most Dx would work as well, I would just rather use a Si though. most of the time its easier to get.
Old Sep 10, 2005 | 11:53 AM
dopey88's Avatar
http://www.thezcr.com lots of different combos there I am using the ZC Inners (you can also use 88-89 teg axles) and the CRX outers
Ralphie
Old Sep 10, 2005 | 12:52 PM
The DX Rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny Black &raquo;</TD></TR><TR><TD CLASS="quote">most Dx would work as well, I would just rather use a Si though. most of the time its easier to get.</TD></TR></TABLE>
tru tru, Thanks
Old Sep 10, 2005 | 05:22 PM
TwztdSi's Avatar
If you have the ZC tranny I don't think you can use the SI axles or DX axles because the ZC tranny uses a half shaft.
Old Sep 10, 2005 | 05:32 PM
ryan89crx's Avatar
Default Re: (TwztdSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwztdSi &raquo;</TD></TR><TR><TD CLASS="quote">If you have the ZC tranny I don't think you can use the SI axles or DX axles because the ZC tranny uses a half shaft. </TD></TR></TABLE>yep, the si axles will work with hf/dx/si trannies...provided you have dx or si hubs
civicslayrx
Dec 9, 2005 08:53 AM
PBrex
Feb 6, 2004 05:13 PM
project dc2
Aug 5, 2003 05:57 PM
pdiddyparsons
Mar 18, 2003 05:59 PM
Civicboy
23
Jun 28, 2002 09:26 AM
