abs on g2?
Old Sep 10, 2005 | 09:52 AM
93integraB's Avatar
Default abs on g2?
problem solved, thanks fellas
Modified by 93integraB at 10:43 PM 9/10/2005
Old Sep 10, 2005 | 09:54 AM
92integraVTECgsr's Avatar
Default Re: abs on g2? (93integraB)
some do.. some dont.. not sure if yours does.. one way to check is to slam the brakes.
Old Sep 10, 2005 | 09:55 AM
93integraB's Avatar
can't, axle is gone need to know to get correct axle, w or w/o abs?
Old Sep 10, 2005 | 10:13 AM
93integraB's Avatar
ok, does it? car is 45 minutes, only reference i've got
Modified by 93integraB at 2:26 PM 9/10/2005
Old Sep 10, 2005 | 10:25 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
no abs !
Old Sep 10, 2005 | 10:26 AM
93integraB's Avatar
thanks, thats what i thought
NickFury's Avatar
NO, you don't have abs on the integra..how you tell if you have abs or not is by looking at where the propotional valve is or where the fuse box is located on the shocl tower..right beside it there should be a huge *** "box unit" where the brake line run to..it should be run behind the intake tube. all you have right thre that i can see is a normal brake proportioinal valve..
normally the GS model for the DA have abs units.
Old Sep 10, 2005 | 10:27 AM
Default Re: (93integraB)
no ABS i believe.. it would be on the passenger side.
Old Sep 10, 2005 | 10:59 AM
LoseRPunKx182's Avatar
behind the intake is the abs unit
Old Sep 10, 2005 | 12:31 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: (LoseRPunKx182)
90-93 integras: LS and RS do not have abs; GS and GSR both have abs. simple as that. btw my abs just **** on me all of a sudden the abs started engaging every time i came to a stop( at about 5 mph). so i just took out the goddamn fuse. i dont know how its defective; the only time i have ever had the abs engage is on ice , and it hasnt snowed for over 6 months
Old Sep 10, 2005 | 03:56 PM
sooo_slow's Avatar
New User
Default Re: (benb18a)
My RS has ABS...
Old Sep 10, 2005 | 05:11 PM
93integraB's Avatar
thanks for the help. got it fixed, up and on the road once again
Old Sep 10, 2005 | 06:09 PM
Tchleung's Avatar
everything is optional You can find an RS with more options then a GS sometimes
eurowned
Dec 3, 2007 03:05 PM
f1nal zeros
14
Aug 16, 2007 05:34 AM
integ3
Dec 5, 2006 10:06 AM
DC5 Type-R
Mar 8, 2002 05:52 PM
