power door lock problem - manual locking doesn't work
Old Sep 10, 2005 | 08:35 AM
zenon's Avatar
Default power door lock problem - manual locking doesn't work
-On my passenger rear door the power locks work, but the manual doesn't.
-I've had the door apart and there's nothing catching the rod or anything of that sort. -The power locks work fine and the manual latch moves lock/unlock as it should, but one cannot move the manual latch itself... It seems to be "locked" or "frozen" into whatever state the door is in (either locked or unlocked).
I replaced the power locking mechanism to no avail... and when that power mechanism was removed the latch assembly works perfectly.
Any Ideas??
TIA
Old Sep 10, 2005 | 08:40 AM
92ehatch's Avatar
Default Re: power door lock problem - manual locking doesn't work (zenon)
i have the same problm on the same door. except mine still unlocks and locks manualy
ive checked all the plugs and such but havent replaced my locking mechanism. so far nothing i have done has helped.
Old Sep 10, 2005 | 09:21 AM
nocturnaldragon's Avatar
I had a similar problem on my car last summer, only with mine neither worked very well just the key. I ended up taking out the lock and latch from my door and cleaning it and re greasing all the pivot points and its worked great ever since.
Old Sep 10, 2005 | 09:33 AM
zenon's Avatar
I tried cleaning and regreasing too...
Old Sep 11, 2005 | 12:17 PM
zenon's Avatar
I have tested it according to the honda repair manual and it is supposedly functioning properly.... it locks/unlocks as it should... except it is "locked" into position, you can't use the latch @ all.
http://cnideria.multiply.com/photos/photo/5/1.gif
MikNomis
11
Sep 16, 2011 02:46 PM
Nickboxer7
Apr 18, 2008 08:32 PM
DJaeMac
Honda Civic (2001 - 2005)
Apr 30, 2007 01:46 PM
jeffsciv23
Dec 20, 2005 10:30 PM
projektvtec
Oct 2, 2005 09:42 AM
