need help taking apart 3 piece rims!!
Old Sep 10, 2005 | 06:58 AM
AnDThEnWuT's Avatar
Default need help taking apart 3 piece rims!!
i have a set of OZ racing 3 piece rims that i'm trying to restore, problem is i dont know what to use to take the individual bolts out. Any ideas on what size sockets or even what tool to use? I'm pretty sure that these bolts are the same size as other 3 piece rims. https://honda-tech.com/zerothread?id=1362492 this should give you guys an idea of how the bolts look like. (a couple of pictures down)
Old Sep 10, 2005 | 08:57 AM
L33t A2's Avatar
Default Re: need help taking apart 3 piece rims!! (AnDThEnWuT)
Those look like the same bolts used on BBS RM and BBS RS wheels.
Old Sep 10, 2005 | 11:59 AM
Qwik_XR's Avatar
Default Re: need help taking apart 3 piece rims!! (L33t A2)
First off, are you sure they are multi-piece wheels? Some wheel manufacturers "mock" the multi-piece design and use PLASTIC bolts that are chromed, and look very much like the bolts in the picture (also used by BBS)..
If they are indeed true bolts, then I think it is 8mm 12pt.. I'll have to doublecheck on mine (BBS) but I think that is correct.
Old Sep 10, 2005 | 09:18 PM
AnDThEnWuT's Avatar
Default Re: need help taking apart 3 piece rims!! (Qwik_XR)
thanks for that info, but yes i'm sure they are real metal and not plastic. I can finally get started on taking it apart.
Old Sep 11, 2005 | 04:04 AM
Qwik_XR's Avatar
I doublechecked.. they are indeed 8mm 12points..
Don't chince with a cheap *** kmart socket.. use quality tools.. else you could be creating alot of unnecessary extra labor
Old Sep 11, 2005 | 01:32 PM
AnDThEnWuT's Avatar
no cheap tools here
medjosh6
Jun 18, 2015 03:22 PM
Prudz_lude
Dec 27, 2012 10:09 AM
osc007
Oct 25, 2011 07:34 AM
lone
Nov 3, 2010 05:27 AM
civic89si666
11
Dec 20, 2006 11:11 AM
