B16a worth how much?
Old Sep 10, 2005 | 06:36 AM
FakeJDMEF8's Avatar
Default B16a worth how much?
i am selling my friend my engine. it has a few bent exhaust valves though, so it doesnt run. its the obd0 b16a from the integra XSi. it has 60,000 miles on the engine. all parts are stock. the tranny is an S1 and grinds a little into 3rd. im including my PR3 ecu, the shift linkage, motor mounts, and the complete motor. i just want to know how much its worth. in general. he is going to build it up and put it in his 93 EG hatch.
any comments are welcome-thanks...
Old Sep 10, 2005 | 06:48 AM
b18_crx's Avatar
Default Re: B16a worth how much? (FakeJDMEF8)
ok whole swap you might get 800-900 because of damged motor.........ur friend has an EG? OBD 1, he will not be able to use ecu..........he will need integra shift linkage and tranny is cable his is hydro.....the only thing that he might be able to use id the motor which is damaged...........OH YEAH motor mount will not work by ur nickname i am assuming that u have an ef and mounts for a b series in ef arent the same for bseries in a EG
Old Sep 10, 2005 | 07:06 AM
FakeJDMEF8's Avatar
what if he gets a boomslang harness-obd1-0? then he can usae the ecu-right? and then a GSR tranny and other mounts? what integra shift linkage? the DA or DC?
Old Sep 10, 2005 | 08:05 AM
b18_crx's Avatar
Default Re: (FakeJDMEF8)
dc SHIFT LINKAGE ..........im not really sure if u can do that anyone else!?
Old Sep 21, 2005 | 05:53 PM
FakeJDMEF8's Avatar
tha mounts are from an XSi in japan...da ones here...
jdmonsta!
13
Jan 6, 2010 02:15 PM
D16SohcVtec
14
Jan 15, 2008 04:49 AM
mod dthispny
May 29, 2007 01:16 PM
Jamison182
May 24, 2003 08:16 AM
