Whats wrong with my tranny?!?!?!?
well i just bought a GS-r
and like have had it for a few days with no complaints
but now its acting pretty weird at first i noticed that when its cold it locks me out of all the gears cant shift it no matter what, unless i turn the car off then back on again
when the car is off it shifts into every gear fine no problem...
sometime times i can put it in reverse and it will open up all the gears
also i noticed that when the clutch is all the way out it makes a whining sound like kinda loud but when i press it in it goes away
any tips or help would be appriciated
sounds like the clutch is toast but when earlier tonight when i was pushing the car the clutch did not slip and motor felt healthy
but when i arrived home i hear that loud whining sound and the clutch would not work
Modified by I got sole.... at 3:35 AM 9/10/2005
update.....
fixed the problem i was just hella low on fluid it was leaking for the pass side axle seal
Modified by I got sole.... at 11:41 PM 9/12/2005
update.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 »</TD></TR><TR><TD CLASS="quote">yea your clutch is done..ive been through that before.</TD></TR></TABLE>
yea thats what im thinking damn.....
my guess the spring in the clutch is coming apart, and is binding between flywheel and clutch.
Your symptoms are identical to mine when it happend to me.
if u have it apart u might as well change the clutch and hell get a flywheel while yer at it or atleast get it resurfaced nothing sucks more than a burnt flywheel with waves in it.
same thing happen to me last month. sometimes it drove perfect, sometimes it wouldnt go into gear at all. and it also made noises. your cluch is dead. sooner or later you wont be able to put it in gear no more. so change it soon before you cant drive it
supereg2
Mar 21, 2008 09:51 AM
J-Brooks
Dec 17, 2002 10:23 AM
