Suspension & Brakes Theory, alignment, spring rates....
Noob suspension questions
Old Sep 9, 2005 | 11:16 PM
alacard's Avatar
Default Noob suspension questions
Lately, I've been researching and trying to figure out a good suspension set up...I was looking into full coilovers, thinking that would be the best setup...but i started reading in H-T and all I see is "Koni + GC's, Koni + GC's". Okay, here are my questions:
-What is the difference between coilovers and struts and shocks and springs and blah blah?
-What exactly is the Koni + GC setup? (are koni the shocks? and gc are the springs??)
-What exactly is a full coilover setup? (for example: d2's)
In the end, I just want to know what exactly is the best setup for my 98 coupe...and what I would need to get.
--thanks in advance
edit: also, I'm still in high school, so this'll be for street use....maybe some track use in the future, but for now..just street. (but i would still want a good setup)
Old Sep 10, 2005 | 11:02 AM
alacard's Avatar
Default Re: Noob suspension questions (alacard)
bump - i need to get going with my suspension - i need help
Old Sep 10, 2005 | 11:50 AM
Solracer's Avatar
[QUOTE=alacard]
--thanks in advance
[\QUOTE]
Koni are the shocks, and Ground Controls are Threaded Sleeves the slip over the Konis to make the fully height adjustable.
A "Full Coilover setup" is a setup where the whole body of the shock is threaded so you can adjust the height of the car.
Both of these setups accomplish the same thing buy doing it differnt ways. Koni's are some of the best shocks in the world.
For you the best setup if you are looking for lowering for looks and a little better handeling, would be too look at lowering springs. These are progressive rate springs that will maintain a close to stock ride while giving you better handeling.
Struts are dampers that also help "locate the suspension" cars with struts do not have an upper control arm, and example would be the RSX.
Your car has shocks, ad does have an upper control arm, the shock only functions damp the suspension nothing more. Most Hondas made from 88-01 had this setup.
Modified by Solracer at 1:27 PM 9/11/2005
Old Sep 10, 2005 | 04:15 PM
Guam_CiviC619's Avatar
Default Re: Noob suspension questions (Solracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote">Your car has <u>struts</u>...</TD></TR></TABLE>
Really? That's news to me.
Old Sep 10, 2005 | 05:02 PM
Solracer's Avatar
Default Re: Noob suspension questions (Guam_CiviC619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Guam_CiviC619 &raquo;</TD></TR><TR><TD CLASS="quote">
Really? That's news to me.</TD></TR></TABLE>
Fixed it... missed typed his car has shocks!
Old Sep 10, 2005 | 07:57 PM
IGotNoSwap's Avatar
if your car is a daily driver, gc's and koni's would be the best bang for your buck.
Old Sep 10, 2005 | 08:55 PM
gob4show's Avatar
Default Re: (IGotNoSwap)
OK would the Koni + GC be a good "kit" for a daily driver/auto x/drag car?? If not what would you suggest?
PS- 95 Civic EX w/ B16
Old Sep 11, 2005 | 04:47 AM
Tyson's Avatar
Fixed it... missed typed his car has shocks! </TD></TR></TABLE>
you also "mistyped" that his "dampers" "damp" the movement of the suspension.
(wtf is a "dampner"? and why would you want to "dampen" your ride and get all wet?)
if youre going to be correcting ppl, know your ****.
Old Sep 11, 2005 | 05:32 AM
Solracer's Avatar
Default Re: Noob suspension questions (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
if youre going to be correcting ppl, know your ****. </TD></TR></TABLE>
I only Mistyped Dampner the rest is correct. and I do know my **** Tyson, Dampers are the correct, if British, nomenclature for shocks/struts and the Dampen or perform a Damping function for the suspension.
Old Sep 11, 2005 | 05:38 AM
Tyson's Avatar
I only Mistyped Dampner the rest is correct. and I do know my **** Tyson, Dampers are the correct, if British, nomenclature for shocks/struts and the Dampen or perform a Damping function for the suspension.</TD></TR></TABLE>
"rest is correct"?
how stuff works... weeee aka "idots guide to things technical".
its a damper. it damps. its not a difference of british nomenclature. difference of those who know suspension (and know how to spell suspenSion) and those who dont.
Old Sep 11, 2005 | 07:20 AM
JonnyCoupe's Avatar
You do realise a 'shock' is a shock absorber which is actually the function of the spring.
Shock = spring
Damper damps the piston travel.
Old Sep 11, 2005 | 08:57 AM
alacard's Avatar
wow, turned into a flame fest..
anyways, thanks to the people who helped.
solracer - I wouldn't want to go with progressive springs, because I do want a better setup, not just something lower....looks dont matter too much to me, at this point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGotNoSwap &raquo;</TD></TR><TR><TD CLASS="quote">if your car is a daily driver, gc's and koni's would be the best bang for your buck.</TD></TR></TABLE>
hmm..seems like that is what ill be going with.
can anyone lead me in the right direction to buying what i need to buy?
is it just the koni shocks for my car, and some ground control coilovers?
anything else?..and if not, where should i look for those?
--thanks a lot guys.
Old Sep 11, 2005 | 09:11 AM
Solracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">hmm..seems like that is what ill be going with.
--thanks a lot guys.</TD></TR></TABLE>
There is a Group buy going on for Ground control and Koni In the sponser section that is a real good buy.
Old Sep 11, 2005 | 09:12 AM
Solracer's Avatar
its a damper. it damps. its not a difference of british nomenclature. difference of those who know suspension (and know how to spell suspenSion) and those who dont.</TD></TR></TABLE>]
Whatever Tyson if you want to be *** and nitpick my typing and engrish go ahead and get in line I am use to it.
Old Sep 11, 2005 | 09:17 AM
alacard's Avatar
alright, ill check it out.
also, i have another question:
if i bought koni's + GC's i wouldnt be getting new springs, right?....so would it be a good idea to buy some springs? and if so, what kind?
Old Sep 11, 2005 | 09:21 AM
Of course your getting new springs when you buy <u>G</u>round <u>C</u>ontrol coilovers. I believe they're springs are manufactured by Eibach.
Old Sep 11, 2005 | 09:23 AM
Solracer's Avatar
Default Re: (alacard)
Yep Ground Control Coilovers come with Linear Rate springs made by eibach.
Old Sep 11, 2005 | 09:29 AM
alacard's Avatar
oooh, alright.
thanks again guys.
and any websites or anything for konis or gc's?
Old Sep 11, 2005 | 10:00 AM
nonsense's Avatar
https://honda-tech.com/zerothread?id=1355904
Old Sep 11, 2005 | 10:58 AM
alacard's Avatar
Default Re: (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1355904</TD></TR></TABLE>
yeah, i saw that..but isnt that price a little steep?
also, im sure they are konis, but why does it say ground control on the shocks, instead of koni?
Old Sep 11, 2005 | 11:02 AM
Tyson's Avatar
the deal is through ground control. no more than marketing reasons i suppose.
Old Sep 11, 2005 | 11:18 AM
alacard's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">the deal is through ground control. no more than marketing reasons i suppose.</TD></TR></TABLE>
so those are koni, and they just have a gc label?
edit: i read the thread..the labels were just for the picture
Modified by alacard at 12:40 PM 9/11/2005
Old Sep 11, 2005 | 11:24 AM
alacard's Avatar
ahhh. sorry for 100 questions. (i am a noob afterall)
but what kind of springs would i want to go for?
for that ground-control link, they have the following:
front:
340 lb/in
380 lb/in
430 lb/in
545 lb/in
rear:
250 lb/in
350 lb/in
430 lb/in
545 lb/in
is this mostly just affecting stiffness, and how the ride feels?
Old Sep 11, 2005 | 12:05 PM
KOALA YUMMIES's Avatar
It affects everything. Do some research, the normal OTS GC rates are 380 lbs/in front 250 lbs/in rear or so, thats what they normally come with.
All these guys like Tyson are more hardcor3z0r (sorry couldnt resist) along with all the roadcourse driving d00ds run rates that promote more rotation out of the car. You'll find that their rates are often a bit stiffer in the rear compared to the front.
For DD and whatnot I would suggest that the OTS rates that GC reccomends would be perfectly fine.
Old Sep 11, 2005 | 01:50 PM
Tyson's Avatar
Default Re: (KOALA YUMMIES)
you got me all wrong, my edible fuzzy haired marsupial friend.
i recommend going with the lowest rate possible for street.
