oem RADIO hook up wires HELP!
Old Sep 9, 2005 | 11:02 PM
zerogravitycrx's Avatar
Default oem RADIO hook up, What Fuse, HELP!
Well my civic came with no radio and had no plug, otherwise it was cut off! but gladly it came with the cut plug! so i resoldered all the wire together and plugged it into an 94-01 oem cd player! and it doesnt work ! so i figure i would be a fuse!
and the help i need is what FUSE would it be underneith the dash? i wouldn't cause i dont have drivers manual or a fuse cover!
please help!
thank you
Modified by zerogravitycrx at 5:13 PM 9/10/2005
Old Sep 9, 2005 | 11:05 PM
nocturnaldragon's Avatar
Default Re: oem RADIO hook up wires HELP! (zerogravitycrx)
Theres also a 7.5amp under the hood you have to check as well that suplies the constant 12v for the clock function that the radio wont function with without.
Old Sep 9, 2005 | 11:06 PM
Default Re: oem RADIO hook up wires HELP! (nocturnaldragon)
Also what yr and make is your car that would help with the fuse identification #'s
Old Sep 9, 2005 | 11:08 PM
oh it's a 96 CIVIC CX hb!
Old Sep 10, 2005 | 01:36 AM
still need your help, what fuse is the radio undernieth the dash?
Old Sep 10, 2005 | 09:54 AM
Old Sep 10, 2005 | 10:23 AM
redpeppers's Avatar
do u have a multimeter? Also is there anything else that is not working in the car, like the domelight?
Old Sep 10, 2005 | 10:28 AM
undertheradar's Avatar
Default Re: oem RADIO hook up wires HELP! (redpeppers)
installdr.com
Old Sep 10, 2005 | 10:36 AM
ok its number 15 under the dash a 15amp fuse
its also number 32 under the hood a 30amp fuse which dosent seem right but its what the book says.
Old Sep 10, 2005 | 03:39 PM
isnt the fuse a 7.5amps for the radio in the egine bay? i replaced that it was burned? undernieth the dash, for #15 was also a 7.5amp and #15 was still a good fuse! well after replacing the one the engine bay, the stock integ cd player has a red flashing light and ejected a cd.
now the cd player will not turn on! all power wire source is solder together following the other misc wires. In order to turn on the CD player is to the enter the code which i have.
any other help! and thanks for your Help
Modified by zerogravitycrx at 5:07 PM 9/10/2005
Old Sep 10, 2005 | 05:04 PM
okay i replaced all fuse for the radio... still cd player is not on, but the anti theft red light flash, asssuming i getting power.
in my 96 civic cx the white wire with blue stripe has constant power, i know by using a test light! the black is ground, yellow orange is the illumination, the other two is red with black strip and a solid red.
now would the solid red, should light up too, right! or is it the red w/ black stripe (when the key is turned to accessories) ?
what i need is a radio wire diagram!
Modified by zerogravitycrx at 6:19 PM 9/10/2005
Old Sep 10, 2005 | 05:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerogravitycrx &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by zerogravitycrx at 6:19 PM 9/10/2005</TD></TR></TABLE>
installdr.com
Old Sep 10, 2005 | 06:13 PM
Default Re: oem RADIO hook up wires HELP! (undertheradar)
cool thanks for the link! is my 96 civic cx radio plug the same as the 00 integra?
Old Sep 12, 2005 | 12:38 AM
all fixed thanks for all the help HT members, just needed a new 12V ignition wire to turn on radio!
97cl2.2
Jun 30, 2009 07:49 AM
y0ungthr0wed
Dec 17, 2007 03:45 PM
herovueboi
Oct 19, 2005 03:58 PM
Tokyo_X-treme_Racer
Audio / Security / Video
Mar 3, 2005 03:45 PM
blackls
Sep 24, 2001 08:40 PM
