95 Civic EX axles question
Old Sep 9, 2005 | 09:42 PM
hmtcrxsir's Avatar
Default 95 Civic EX axles question
I have a 95 Civic EX. My friend have a set of 95 Civic DX axles. So can i use axles from a 95 Civic DX non ABS? Does it matter if it is ABS or non ABS? My civic is non ABS. Can i use the one that is ABS? Vice Versa?
Old Sep 9, 2005 | 09:59 PM
ntrider's Avatar
Default Re: 95 Civic EX axles question (hmtcrxsir)
i believe that the d-series axles 92-00 are interchangeable. non-abs to non-abs and abs to abs, but as far as non-abs to abs i don't know. However since you mentioned that you didn't have abs it should be fine. If I am wrong hopefully someone will correct me.
Old Sep 9, 2005 | 10:05 PM
JDM_DC4_Fanatic's Avatar
i'm not 100% sure bout how interchangeable they are, however I do know the diffeence between the axels. If you are gonna have any problems, its gonna be because of the teh on the end of the axels not clearing the spindal or something, if this happens, just grind down the teeth till the axels fit, other then that, the spline count is the same, as well as the length, so, it shouldent be a big deal, and i'm 80% sure it will just slip in
Old Sep 9, 2005 | 10:07 PM
Default Re: 95 Civic EX axles question (JDM_EK_Fanatic)
i'm a moron who cant type, the abs axels have teeth on the end of them, grind those down if it doesnt fit, but it should
Old Sep 9, 2005 | 10:13 PM
b18ccivics's Avatar
they will all fit, abs axles on non abs car
bob441
Nov 11, 2015 06:50 PM
realis9
May 30, 2008 12:55 AM
tso
Nov 25, 2007 11:49 AM
civic702
Feb 23, 2004 04:20 PM
charjacq
Mar 2, 2003 09:21 AM
