Transmission + lots of HP = what solution?
Old Sep 9, 2005 | 09:39 PM
Azcheron's Avatar
Default Transmission + lots of HP = what solution?
if i was going to run about 350whp on my daily driver through the stock ITR tranny with a turbo....what could i do to the tranny to make it stronger?
or does anyone have experience with a better, stronger aftermarket tranny?
any companies that people have experienced to make better synchros, trannies, gears?
all comments welcomed
this discludes all talk about clutch, flywheel
this is direct tranny related items only
thanks
Old Sep 9, 2005 | 09:56 PM
Haleiwa-Brando's Avatar
Default Re: Transmission + lots of HP = what solution? (Azcheron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">if i was going to run about 350whp on my daily driver through the stock ITR tranny with a turbo....all comments welcome </TD></TR></TABLE>
I have no idea what you can do to your tranny, but you can start off by buying my turbo system
Old Sep 9, 2005 | 10:07 PM
nholmes's Avatar
Default Re: Transmission + lots of HP = what solution? (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">
I have no idea what you can do to your tranny, but you can start off by buying my turbo system </TD></TR></TABLE>
and selling me your JRSC system Azcheron
eMpAtHy's Avatar
well, as a daily driver, i dont think you will be constantly revving at 8000 and downshiting to 8000 when u turn, so at this point, i doubt you would need it. i dont know how weak the ITR tranny is, but my h23 tranny held up fine with 300 whp. h22/23 trannies are known to be weak too.
what you might want to look into a aftermarket clutch to hold all that torque. you could also cryo treat your synchro's and such. i dont know how much it costs though.
Old Sep 10, 2005 | 02:10 AM
Stein's Avatar
Default Re: Transmission + lots of HP = what solution? (eMpAtHy)
Wait, I thought you were selling the R?
Old Sep 10, 2005 | 04:00 AM
typer_696's Avatar
You should look into installing the carbon coated syncros, shifts are alot smoother and works a lot better when high reving
Old Sep 10, 2005 | 07:06 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">if i was going to run about 350whp on my daily driver through the stock ITR tranny with a turbo....what could i do to the tranny to make it stronger?</TD></TR></TABLE>
Spend your money elsewhere. Unless you're running slicks, you should be OK with just a clutch.
-Chris
Old Sep 10, 2005 | 08:15 AM
Jowee's Avatar
Default Re: Transmission + lots of HP = what solution? (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
-Chris
Yupp. I've seen OEM trannies with 400+ hp with nothing more than axles and a good clutch hold up fine.
Old Sep 10, 2005 | 08:48 AM
Dr Pooface's Avatar
Default Re: Transmission + lots of HP = what solution? (Jowee 1162)
What Chris said.
Old Sep 10, 2005 | 12:41 PM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">any companies that people have experienced to make better synchros, trannies, gears?
I did some research on this a while back ago, and the only company I found that makes stronger trannys for the ITR is Xtrac in the UK. http://www.xtrac.com
It's extremely expensive though. 13000£ I think they go for. But they are able to take all boost you can throw at them with no problem.
Old Sep 10, 2005 | 01:01 PM
Dr Pooface's Avatar
Default Re: Transmission + lots of HP = what solution? (Pompiuses)
Why not just get the dog box kit from http://www.housemanautosport.com/ ?
Much cheaper.
Old Sep 10, 2005 | 03:21 PM
Azcheron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 &raquo;</TD></TR><TR><TD CLASS="quote">
Yupp. I've seen OEM trannies with 400+ hp with nothing more than axles and a good clutch hold up fine. </TD></TR></TABLE>
im sorry, but i dont agree with that at all
im pretty gentle on my car
but i do whip it around on occasion, and with the high redline of our cars with a lot of power and agressive clutch and flywheel....
ive already replaced my synchros twice
my clutch and everything else is mint after driving hard for many miles, but my first synchros went after 45k, then second set went after 20k with the JRSC on
Old Sep 10, 2005 | 03:22 PM
Azcheron's Avatar
BTW im referring to an ITR engine, but not my ITR. The one for the future project
my ITR is still for sale
Old Sep 10, 2005 | 03:45 PM
CRVRX's Avatar
Unless you drop the clutch with slicks , the ITR tranny will hold 400+ no worries.
Mine is stock with a quife and holds 500+ no sweat.
Old Sep 10, 2005 | 03:50 PM
Jowee's Avatar
my clutch and everything else is mint after driving hard for many miles, but my first synchros went after 45k, then second set went after 20k with the JRSC on</TD></TR></TABLE>
That's fine. I'm nowhere near gentle on my car and have 93,xxx miles on it with no grinds or tranny problems at all. The only trannies I've ever seen totally destroy themselves were with insanely high hp.
Old Sep 10, 2005 | 05:23 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">ive already replaced my synchros twice</TD></TR></TABLE>
Maybe there's something wrong with your driving style, because power doesn't wear out synchros, shifting does.
Old Sep 10, 2005 | 09:57 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Maybe there's something wrong with your driving style, because power doesn't wear out synchros, shifting does.</TD></TR></TABLE>
Winner!
Old Sep 11, 2005 | 05:53 AM
Dogginator's Avatar
Daisy... Daisy...
Quaife claims that the stock ITR LSD can't handle high horsepower.
https://honda-tech.com/zero...28924
Old Sep 11, 2005 | 06:32 AM
.RJ's Avatar
.RJ
Yep....
I've never broken or worn out a synchro in track use
Old Sep 11, 2005 | 10:31 AM
Padawan's Avatar
Darth ModerVader
Default Re: Transmission + lots of HP = what solution? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Quaife claims that the stock ITR LSD can't handle high horsepower.
https://honda-tech.com/zero...28924</TD></TR></TABLE>
As I'm sure you were able to discern from your email correspondence, Quaife does not appear to have any empirical evidence to support its claim, and is presumably using such statements more as a marketing ploy than anything else. Of course, one would indeed expect a performance after-market differential to be stronger than an OEM unit, but for the great majority of individuals, the ITR LSD will likely be completely sufficient.
Old Sep 11, 2005 | 10:49 AM
Stripped Honda's Avatar
99-0104
you need to llearn to shift ... i have yet to kill my syncros...
Old Sep 11, 2005 | 10:59 AM
nholmes's Avatar
Default Re: Transmission + lots of HP = what solution? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
As I'm sure you were able to discern from your email correspondence, Quaife does not appear to have any empirical evidence to support its claim, and is presumably using such statements more as a marketing ploy than anything else. Of course, one would indeed expect a performance after-market differential to be stronger than an OEM unit, but for the great majority of individuals, the ITR LSD will likely be completely sufficient. </TD></TR></TABLE>
DING DING!
Winner!
Old Sep 11, 2005 | 03:54 PM
Azcheron's Avatar
Default Re: Transmission + lots of HP = what solution? (nholmes)
power doesnt affect synchros?
who told you that?
i am a very good driver
i dont down shift more than a gear at a time
when i down shift, i always rev match
and i cant be that bad a driver, since my clutch and flywheel look great
synchros in our cars is a common and known issue
those who havent had the problem are lucky
many many many posts about trannies and synchros on every honda forum ive ever been on
anyone have experience with any of the above mentioned trannies or coatings?
where to get and how much?
Old Sep 11, 2005 | 04:05 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">synchros in our cars is a common and known issue
If you abuse your transmission
Or if you are just rough with it - anything will break given enough abuse and time
And dont change your gearbox oil often
Given the state of tune of your engine w/ the JRSC...... I would suspect you treat your transmission the same way
Its not a "common" problem at all if you excercise a little care
Take care of your equipment and it will take care of you
And stop posting like this.
Old Sep 11, 2005 | 04:50 PM
Azcheron's Avatar
Default Re: Transmission + lots of HP = what solution? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
And stop posting like this.</TD></TR></TABLE>
lol, wtf
what state of tune?
my car is tuned to perfection
it was only tuned wrong for like a week
dont speak unless you know what you are talking about
my car runs flawlessly in every way
couldnt ask for a more perfect tune
