90 integra brakes on 92 civic hb
Old Sep 9, 2005 | 07:10 PM
91teg's Avatar
Default 90 integra brakes on 92 civic hb
i was wonderin on the front brakes what all i needed? the rotor and caliper or the whole assembly? on the rear brakes (drum to disk on the hb) do i need the cable for the e-brake? thanks
Old Sep 9, 2005 | 07:14 PM
kaiba's Avatar
Default Re: 90 integra brakes on 92 civic hb (91teg)
Not sure bout the front if it fit or not(i actually would like to know that too). But as for the rear. You'll need 92-95 civic si ebrake cable + brake lines. Also you'll need an integra 4040 proportioning valve along with bigger brake booster w/ 1' or 15/16 master cylinder.
Also it's a smart idea to change the trailarm bushing while your at it.
Old Sep 9, 2005 | 08:19 PM
BlueIntegraBoy's Avatar
The fronts will not fit the hatch after researching. I found out the hard way after investing $300 for the front brakes.
Old Sep 10, 2005 | 07:57 AM
becoming's Avatar
The rears wil not fit either, get some off of an integra from 94-01 to go onto your 92 hatch....they will fit just right And yes, you will need the e-brake cable from the integra too
Old Sep 11, 2005 | 02:43 AM
Default Re: 90 integra brakes on 92 civic hb (becoming)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by becoming &raquo;</TD></TR><TR><TD CLASS="quote">The rears wil not fit either, get some off of an integra from 94-01 to go onto your 92 hatch....they will fit just right And yes, you will need the e-brake cable from the integra too</TD></TR></TABLE>
The rears WILL fit. Everything is pretty much the same between a 90-93 and 94-01 Integras except that the 90-93 Integra trailing arm has a larger diameter bushing, which will not make any difference in bolting up.
Woogie Ctr
11
Apr 14, 2013 12:23 PM
93preludeh22
18
Mar 9, 2013 06:33 AM
IChazI
Mar 22, 2008 12:41 AM
**DOHC HaTcH**
Mar 21, 2007 12:48 PM
