92-95 rear hatch window/ support mounts
#21, 22, 23
just want to double check before i order, are these all the parts needed for the bottom of the support strut to attach to the rear hatch glass?
Both of mine are stripped now so i'll need to replace them... do they just pop out from the glass?
I replaced mine about a year ago for the same reasons. Just a heads up for ya. I ordered all 3 too and didnt really end up needing them all. The only part that really strips out is 21. 22 is a rubber sealing washer and 23 is the plastic locknut that holds 21 to the glass. and yes once you unscrew 23 it just pops right outta the glass. takes like 2 minutes for both.
i replaced mine when i got my car. does #22 go outside the glass or on the inside? didnt have any to begin with so i put it on the inside because 21 and 23 are both notched and fit together but the rubber washer seemed to prevent them from going together when i put it on the outside.
BTW it doesnt leak even with them on the inside. just wondering how it is from factory.
for a 12 year old car, with all the opening and closing its bound to get stripped out. glad im not the only one with this problem! now if only they didn't come out to be like 25$ plus shipping for both sides
x916
May 17, 2004 10:23 PM
