Question regards to B18C5 Engine swap
i am about to swap the engine to my GS now here are the things i have to ask
i would like to keep my AC and the ITR engine are also missing PowerSteering and alternator.. i am just wondering if the NonVtec one's would fit and do i have to change the belts to ITR spec. or i can use the nonVtec one's..
it's a 00' B18B1 vs 99 B18C5
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R »</TD></TR><TR><TD CLASS="quote">Probably a Hybrid question.
However, You can use accessories from your LS motor.
Good Luck</TD></TR></TABLE>
understood
thanks
understood
thanks
Just use all your oem GS parts that are missing from the ITR swap. The worst thing you'll have to do it make a few runs to the local autoparts store for belts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 »</TD></TR><TR><TD CLASS="quote">Just use all your oem GS parts that are missing from the ITR swap. The worst thing you'll have to do it make a few runs to the local autoparts store for belts.</TD></TR></TABLE>
LOL
thanks guys..
yeah i know that's what i was thinking just use it anyways.. if it doesn't fit just like you said go to Acura
LOL
thanks guys..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid-TrixC5 »</TD></TR><TR><TD CLASS="quote">Where did the 99' C5 come from. I thought there were no 99 R's?</TD></TR></TABLE> ... i can't believe you ask me this, you live in Canada too... anyways... do a search next time
FYI: 99' R didn't make it in the states but Canada did
https://honda-tech.com/zero...age=9
For my GSR I needed new belts for the alternator and air conditioning since the ITR crank pulley is smaller. For the GS I believe you can reuse the AC belt depending on year. 4PK0830 was the size I used.
All plugs should be direct plug in since you are the same OBDII harnesses. You will need to add the VTEC and knock sensor wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AW »</TD></TR><TR><TD CLASS="quote">For my GSR I needed new belts for the alternator and air conditioning since the ITR crank pulley is smaller. For the GS I believe you can reuse the AC belt depending on year. 4PK0830 was the size I used.
thanks for the reply
do you know how to wire those 3 Vtec wires? i can easily figure out the cabine harness(ECU) part but from the ECU to the engine harness... i am not too sure about it..
00bluesi
Feb 19, 2006 10:39 AM
