Installed Cusco rear sway and Spoon lower tie on EP3.
Old Sep 9, 2005 | 04:50 PM
knowledge112's Avatar
Default Installed Cusco rear sway and Spoon lower tie on EP3.
Thanks to jdmd for the hookup. I must say it feels alot nicer with the new editions. I'm still waiting to pick up the Spoon front and rear upper bars, so I can only expect it to get better. Don't post to much, but I was alittle excited when cruising around after the install. Later.
Old Sep 10, 2005 | 01:56 PM
The Cusco rear sway is 25mm. Let me tell you that it is huge compared to the stock bar. Spoon bar is alittle dirty...just washed car and got some water spots. Hope the pics help.[IMG][/IMG] [IMG][/IMG]
Modified by knowledge112 at 11:18 PM 9/10/2005
Modified by knowledge112 at 11:19 PM 9/10/2005
Old Sep 10, 2005 | 02:45 PM
jdmd's Avatar
good stuff there steve. my car definitely feels different now that it's back to stock down there too. oh well, i know the bars will be put to use in your car. as will the front lower and rear upper's.
Old Sep 10, 2005 | 03:21 PM
jdmp's Avatar
Default Re: (jdmd)
schweeet
Old Sep 10, 2005 | 06:07 PM
in-n-outboy's Avatar
Default Re: (jdmp)
nice i want one
Old Sep 12, 2005 | 07:14 AM
Im not to sure about what other companies offer a 25mm bar. You couldnt go wring with getting Cusco or Mugen.
Old Sep 12, 2005 | 08:05 AM
ff terror's Avatar
too old for school
Default Re: Installed Cusco rear sway and Spoon lower tie on EP3. (knowledge112)
Thats a huge sway bar!
Does the tail end kick out when going fast around a curve?
Old Sep 12, 2005 | 10:05 AM
DC5ITR329's Avatar
Default Re: (knowledge112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knowledge112 &raquo;</TD></TR><TR><TD CLASS="quote">The Cusco rear sway is 25mm. Let me tell you that it is huge compared to the stock bar. Spoon bar is alittle dirty...just washed car and got some water spots. Hope the pics help.[IMG][/IMG] [IMG][/IMG]
Modified by knowledge112 at 11:19 PM 9/10/2005</TD></TR></TABLE>
bar looks good but I think the bushings aren't the right ones. I have the mugen 25mm bar and it doesn't do that to the bushings.
Old Sep 13, 2005 | 03:14 PM
The bushings are the right ones. The bar came off a friends car that had it on for alittle while. Being a used bar maybe has affected the appearence of the bushings. I dunno. Its on there nice and tight too. The back end doesn't feel as if im losing control when going around corners. If anything, it makes my rear end feel nice and tight. Just the way it should be! Seriously, the bar has def. enhanced the suspension and I personally can't wait til im finished with the suspension and feel the overall effect.
Old Sep 13, 2005 | 09:22 PM
Redline96LX's Avatar
* B A N N E D *
holy crap its BIG ****** BLUE!
Nice info tho, and man, thats huge. Do you oversteer now?
Old Sep 13, 2005 | 11:21 PM
mrDFWmechanic's Avatar
i upgraded my 02 civic from the oem 15mm to the DC5 22 mm bar it made a freakin huge difference. i thought mine was huge and you proved me wrong sir.
Old Sep 14, 2005 | 12:43 PM
DC5ITR329's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knowledge112 &raquo;</TD></TR><TR><TD CLASS="quote">The bushings are the right ones. The bar came off a friends car that had it on for alittle while. Being a used bar maybe has affected the appearence of the bushings. I dunno. Its on there nice and tight too. The back end doesn't feel as if im losing control when going around corners. If anything, it makes my rear end feel nice and tight. Just the way it should be! Seriously, the bar has def. enhanced the suspension and I personally can't wait til im finished with the suspension and feel the overall effect.</TD></TR></TABLE>
I have the mugen 25 and my bushings look like they fit like stock. I'm not sure. maybe you got ITR 22mm ones and he just sqeezed it in there.
egk3vin
Jan 7, 2010 06:48 PM
jdm-ray
Honda S2000
Jul 2, 2007 07:50 AM
bacardiboi
Suspension & Brakes
12
Apr 12, 2007 10:14 AM
JDMchris
Jun 6, 2002 09:18 PM
