Help with DTC's...
I have a 92 prelude SI with a 2001 2.2 vtec in it. I bought it with the swap already done. I jumpered the connector to access the codes and I got Codes 1,21, and 22.... I guess 1 is the oxygen sensor circuit fault, 21 is the vtec oil pressure switch, and 22 is the Vtec actuator/solenoid.... I need to get my check engine light to stay off because I have to pass emissions soon. The engine runs great and vtec works and everything. I dont know where to start with this because the original harness and computer were retained and i guess he put some kind of chip in it to allow vtec to be used. I would really like to find a page about how to put an OBD2 engine in a OBD1 car because he kept it OBD1 and I want to be able to fix this. I assume since the CEL is on, the computer is using preset values for the air/fuel mixture, so that can't be good for extended use. I have put over 2000 miles on it since I got it and have had no problems. Pleae someone point me in the right direction. I am a Jeep Tech so I do have knoweledge to some extent of electrical, but I would like to see from a conversion article what wires he actually ran and where they go. Thanks alot guys!
~Joe~
P.S
I'm also have some oil consumption. The engine has around 40k on it and no leaks whatsoever, and no blue smoke... I go through about 1 qt every 1k miles... this seems alot, could it be valve seals seeping by? or is my CEL causing a rich mixture which is washing the pistons off and then it is getting by the rings? any ideas?
~Joe~
P.S
JustinG60
Jul 12, 2006 11:57 AM
