vtec vfac de wiring back 2 stock
i need the wiring diagram for a vfac2 controler for my jdm h22a in my 95 lude, i disconnected it and lost the instructions. so i need to know which wires to reconnect together to make the cel go off. I think its the yellow and the white. Not so sure apexis website is in half japaneese and they dont list wiring for a vfac just the sfac thanks
the wiring for the vafc should be self evident. look for the wires that were cut, match up the colors of the wires, and reconnect them with connectors. all the other wires are just spliced in, so all you should need to do it re-wrap them in electrical tape.
yellow and white wires from the vfac2 is the pressure signal, yellow is output white is input, blue is VTM signal, purple and pink is vtec, gray is throttle, green is rpm, brown and black is ground, orange is vtc cam signal and light blue is tdc signal, im not really sure of the question so i juss give u the list of the wires for the apexis vafc2 hahaha hope it help though
awesome man thanks, like i had the vtec wired in so i got a green and a blue im tryin to figure out... i found out that the gray and the purple went together also....
im not too sure wat vtm for, i use it n i dun have ivtec in my h22a, and i think either the orange or the light blue wire is for ivtec, not too sure
LuckyStrike90
Feb 15, 2018 01:42 PM
hondaZvic
Apr 22, 2004 12:51 PM
