which itr ecu's will work on my 99 GSR
Old Feb 27, 2002 | 02:53 AM
comptechgsr's Avatar
Default which itr ecu's will work on my 99 GSR
the 97-98's r direct plug n plays...
while the 00-01 need the immobilizer to be removed...
am i correct?
Old Feb 27, 2002 | 04:50 PM
mugenracer's Avatar
Default Re: which itr ecu's will work on my 99 GSR (comptechgsr)
you will have to change the T/B to ITR one as the ITR ECU wont recognise the secondary runners on the GSR's inlet manifold, plus VTEC engagement is at 5700rpm, whereas the GSR crosses over at 4400rpm, so all in all stick with the GSR ECU and get it chipped to your own specifications
Old Feb 27, 2002 | 09:12 PM
t's Avatar
t
Default Re: which itr ecu's will work on my 99 GSR (mugenracer)
Change the T/B?
Old Feb 28, 2002 | 04:43 AM
eg6ajk's Avatar
Default Re: which itr ecu's will work on my 99 GSR (t)
i belive he meant upgrade to SKunk2 manifold which is a single butterfly intake (not a dual stage).
insetead of chipping your obdII ecu ($$$) or going with ITR (which need the imobilizer taken off, go with a harness converter + obdI ecu
Doubledeala
Oct 14, 2004 06:47 PM
smkngsr
Sep 23, 2003 01:16 AM
guyuenvy
Apr 30, 2002 08:30 PM
rsx03
Mar 27, 2002 06:59 PM
1fastGSR
Aug 19, 2001 09:13 PM
