Air Fuel Ratio
Old Sep 9, 2005 | 02:04 PM
Mike3728's Avatar
Default Air Fuel Ratio
i have an 05 civic ex and i installed my afr guage. i hooked the violet up to the white on the o2 and grounded it and ran the power to the ig but i dont get a reading. the guage lights up but it doesnt bounce back and forth it only stays on green like it would if u didnt hook the o2 wire up..... soo if anyone can help me out and let me no y im not getting a signal or what im doing wrong thanks
Old Sep 9, 2005 | 02:20 PM
I cant believe this shit's Avatar
Default Re: Air Fuel Ratio (Mike3728)
Sounds like its not getting a good read from the o2 sensor. Its been a while since I had one so I don't remember where the wires need to go.
Old Sep 9, 2005 | 06:49 PM
tfnaaf's Avatar
its pretty much a useless guage, i recommend a wideband but to each there own. Sorry cant be helpful, never hooked a narrow band up b4
Old Sep 12, 2005 | 04:40 PM
Mike3728's Avatar
Default Re: (tfnaaf)
the guage is an auto meter. u think it could be the guage it self then? i mean everyone i talk to tells me something dif i just wish i could get this problem solved been working on it for like 2 weeks now. don't think i need a new o2 sensor do you...??
Old Sep 13, 2005 | 07:12 PM
bricks2k4civic's Avatar
try connecting it to the black wire on the sensor with the grey connector.
Old Sep 13, 2005 | 07:48 PM
eMpAtHy's Avatar
Default Re: (Mike3728)
non-wideband afr guages are basically useless. they're only useful when you're running lean from idle to wot or rich from idle to wot. besides that, you will not get an accurate reading. dont tune your afr with that thing either.
Mike3728's Avatar
Default Re: (bricks2k4civic)
theres 2 black wires a green and a white. the white wire is the signal wire which is where u need to connect the purple wire 2 but im not getting a reading. may be it is the black wires but im sure its the white.......
Old Sep 13, 2005 | 07:50 PM
Mike3728's Avatar
Default Re: (eMpAtHy)
thats the thing im not getting any type of readings it should be bouncing back and fourth but its not.... thats y i dont no if its the sensor or just a bad guage.....
Old Sep 14, 2005 | 08:40 AM
...me0w's Avatar
you need to hook your signal wire up to the wire running to the pcm. on my 02 its the white/red wire on the connector to the far left if you looking at the pcm from the passenger seat. the pcm is directly behind the glove box and they are correct do not tune from it, but thats how you hook it up i had the same issue with mine also.
Old Sep 14, 2005 | 01:50 PM
Mike3728's Avatar
Default Re: (02SHRTBUS)
the pcm which wire behind the glove box u said the white wire/red stripe on it but tehres about a bunch of the same color wires.......
Old Sep 14, 2005 | 04:59 PM
thielke2004's Avatar
im having truble wit the rsx i have an 03 and do not know how to get it working try hooking it up to the ecu but it does not work when i hit the gas only when im costing it works its kinda weird
Old Sep 15, 2005 | 07:48 PM
park83rsx's Avatar
Its not getting a good signal because the stock 02-04 RSX/EP3 O2 sensor is a wideband (well, actually "semi-wideband technology") and the autometer guage is a narrowband guage. The voltage ranges are different and thus, your signal will be way off. Trust me, I had one too.
Old Sep 16, 2005 | 01:12 PM
...me0w's Avatar
its the connector to the far left if your sitting in the passenger seat another thing is where are you located and is your car rhd if so it might be completely different just though i would ask i have no issues out of mine it works properly let me know what you find out
Old Sep 16, 2005 | 02:17 PM
The only way mine worked was connected to the black wire on the sensor AFTER the cat.
99delsol
Oct 3, 2006 08:40 PM
88crxhfb16
Jul 1, 2005 08:19 PM
turbo_b16_ex
Jan 20, 2005 11:24 AM
harwood39
10
Jan 19, 2005 12:51 PM
ScottEK
May 11, 2004 02:31 PM
