H-T's Boosted Accords... POST PICS HERE
Lets see Honda-Tech's Boosted Accords. I haven't seen much but I read there is alot. So let's see them... I will start off with mine...
PANTY DROPPER (baby brother)
Turbonetics T3/T40E Stage III 63 trim
Custom DIY Ramhorn Manifold
Drag 4 IC piping
JRC 6" IC
Tial 38mm Wastegate
Blitz DD Blow Off Valve
Custom 2.5" downpipe
6" flex pipe
Magnaflow Carsound Cat
AEM Fuel Pressure Regulator
Walbro 255 Fuel Pump
OBD2B-> OBD1 conversion Harness
DSM 450cc Blut Top Injectors
Golden Eagle Vacuum Manifold
38mm Dumptube
P06 chipped with Uberdata boosted at 8psi
Drag 4 IC piping
JRC 6" IC
Tial 38mm Wastegate
6" flex pipe
38mm Dumptube
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX »</TD></TR><TR><TD CLASS="quote">what time did you run?</TD></TR></TABLE>
I'm going to the track today... We'll see. I won't run if I can't find drag radials to buy. I'm calling almost every tire store in my COUNTY. I NEED SOME G-FORCES!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhdune16 »</TD></TR><TR><TD CLASS="quote">BUMP....</TD></TR></TABLE>
time?
time?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhdune16 »</TD></TR><TR><TD CLASS="quote">BUMP... </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX »</TD></TR><TR><TD CLASS="quote">what kind of numbers do those sohc accord motors put down boosted?</TD></TR></TABLE>
ditto?
ditto?
around 240-265 at 10psi depending on setup.... i haven't dynoed yet... but I ran a 13.8 1/4mile untuned on 8psi. At 10psi i'm around 250-255 and I am tuned now. I can keep up with a turbo LS motor boosting at 12.5psi and he runs 12.8's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCalGsR1 »</TD></TR><TR><TD CLASS="quote">the 2 picture posted are 4drs accord..weird </TD></TR></TABLE>
