Spark plugs
Old Sep 9, 2005 | 08:35 AM
wpsadmin's Avatar
Default Spark plugs
I got the car at 29k miles, and it's now 47k, not really sure if last owner ever change spark plugs.
How would I know it's time to change it? the car is running just fine right now.
Old Sep 9, 2005 | 08:46 AM
Flux's Avatar
Default Re: Spark plugs (wpsadmin)
I would change them. Maintenance is cheap but will go along way to making your car last longer and gives you peace of mind.
Old Sep 9, 2005 | 08:49 AM
JDM Factor's Avatar
Doesn't the dealer change them at 75k lol?
Old Sep 9, 2005 | 10:01 AM
92TypeR's Avatar
FSAE
Default Re: (JDM Factor)
NGK Copper part# BKR6E-11, you can get a complete set for under $10.
Copper plugs you should change every 15-20k miles. Platinum I would change every 40k miles, so you are due I would say.
Old Sep 9, 2005 | 11:34 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">NGK Copper part# BKR6E-11, you can get a complete set for under $10.
Copper plugs you should change every 15-20k miles. Platinum I would change every 40k miles, so you are due I would say.</TD></TR></TABLE>
Not too much faith in platinum....
Old Sep 9, 2005 | 11:44 AM
98 Spec R's Avatar
I run the S2000 Platnium Plugs. They are a 7 heat range instead of a 6.
They are also the plugs which come stock in the JDM ITR motors.
The only down side is since they are platnium, they run about $17 a piece.
Old Sep 9, 2005 | 12:43 PM
Dave_B's Avatar
Just changed mine today with Denso Plat. Cost me $6 a plug. Cheap to do. I say go for it.
Old Sep 9, 2005 | 01:40 PM
KOALA YUMMIES's Avatar
Default Re: (Dave_B)
I just use the regular normal NGKs, the guy at the dealer told me they require the Iridium or platnum or whatever the heck and I asked to speak with someone else
uLTrAvTEc757
Honda Civic (2006 - 2015)
Sep 5, 2006 05:27 PM
2k1 GSR
Jan 12, 2003 02:33 AM
TeamTooQuick
Jun 19, 2002 10:12 PM
paulyman
Feb 25, 2002 12:13 AM
GoLowDrew
Nov 21, 2001 10:45 AM
