Put on new intake manifold and now throwing 5 cels! Help
Old Sep 9, 2005 | 07:53 AM
9hatchman4's Avatar
Default Put on new intake manifold and now throwing 5 cels! Help
Hey guys, I have a 94 civic hatchy with a boosted gsr motor in it, I just threw on a new Blow intake manifold yesterday, and now I'm throwing 5 codes; 3,7,23,41,and 43. I believe that's MAP, TPS, Knock Sensor, O2 Sensor, and Fuel Supply System. Could the Map and TPS wires be mixed around, and what is that sensor that sits near the IACV on the intake manifold kinda close to the throttle body? Has a black cap that comes off. Also could the MAP sensor code be because of me not having a check valve? The knock Sensor is not wired in so that's one down. I just rewired an O2 sensor so I don't see what the problem is with that, and the the Fuel Supply System? Could this be bad injectors? I put in my stocks again cause I'm running an SAFC so I just richened it up, but the tips of the injectors are broke, could this cause the cel? Anyway sorry so long, but I'm just trying to get this thing running good.
Old Sep 9, 2005 | 08:10 AM
Andres-eh2's Avatar
Default Re: Put on new intake manifold and now throwing 5 cels! Help (9hatchman4)
looks like tps and map are indeed crossed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9hatchman4 &raquo;</TD></TR><TR><TD CLASS="quote"> I just rewired an O2 sensor so I don't see what the problem is with that, </TD></TR></TABLE>
how dont you see the problem? i see it!
You need to reset the ECU for +/-10 minutes
Old Sep 9, 2005 | 08:59 AM
9hatchman4's Avatar
Default Re: Put on new intake manifold and now throwing 5 cels! Help (Andres-eh2)
Alright I'll check those two today, and do you happen to know what that other sensor is, it's bolted to the throttle body on GSR's and it has a black cap and the harness plugs into the side of it. Just wondering cause one of the wires is cut.
Old Sep 9, 2005 | 10:00 AM
BoOstedEM1's Avatar
Thats sounds like your tps..is it directly across from your Tb butterfly lever thingy...
Old Sep 9, 2005 | 10:04 AM
9hatchman4's Avatar
Default Re: Put on new intake manifold and now throwing 5 cels! Help (BoOstedEM1)
No, it's not the tps, it's right next to it though, it has a vacuum hose, and has a black cap that comes off, I'm not sure what it is, somebody told me that it was part of the map and I should run my check valve to that hose. Where do you all have your check valve at for the map sensor, I need to put one in.
Old Sep 12, 2005 | 02:23 PM
Andres-eh2's Avatar
Old Sep 12, 2005 | 03:15 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9hatchman4 &raquo;</TD></TR><TR><TD CLASS="quote"> and the the Fuel Supply System? </TD></TR></TABLE>
Probably something to do with the o2 wiring.
handa
13
Jun 28, 2004 06:31 AM
Blkcoupe
Aug 17, 2003 12:16 AM
sporkcrx
17
Jul 21, 2003 08:22 PM
v-attack
Jul 16, 2003 01:07 PM
dose
Apr 7, 2003 06:52 PM
