5th gear grind
Old Sep 9, 2005 | 07:21 AM
projectTeG's Avatar
Default 5th gear grind
ok this is for a buddy of mine with a 92 cb7 ex, when he goes from say 2nd gear into 5th it makes a definite grind and if done a few time you can smell the metal to metal contact, smells like when you grind something down with a grinder. it also does it when going from 3rd to 5th and 4th to 5th. i was wondering could this be due to a lose cable or what, im not used to the cable shifting transmissions since i come from the bar type integras. im trying to check all options before i tell him his trans is going. BTW the tranny fluids been changed, i might tell him to try Gm syncomesh
Old Sep 9, 2005 | 07:41 AM
smithenhiven's Avatar
11:11
Default Re: 5th gear grind (projectTeG)
5th Gear synco is probably going. It happens to me in my CB7 in 3rd gear all the time.
Old Sep 9, 2005 | 09:39 AM
honest.hank's Avatar
Default Re: 5th gear grind (smithenhiven)
i think i may be having a similar problem (grinds going from 4th to 5th). is this an expensive (or pain in the ***) fix?
Old Sep 9, 2005 | 09:48 AM
11:11
Default Re: 5th gear grind (honest.hank)
It's not cheap, nor easy, unless you're an experienced mechanic. Personally, I would replace the entire tranny before tearing it apart to replace a synchro.
Old Sep 9, 2005 | 11:09 AM
would it be bad to keep driving it with the bad synchro?
Old Sep 18, 2005 | 09:30 AM
projectTeG's Avatar
oh ok, welp looks like my buddis gonna get his h-series swap a lil faster than he thought...lol
SoCalian_SD
Jan 18, 2009 07:43 AM
94jdmlude
Dec 30, 2008 02:38 PM
92eg6lsvtec
Jul 9, 2008 07:08 PM
John
Feb 12, 2002 12:16 PM
