skunk2 stage 2?
Old Sep 9, 2005 | 06:38 AM
jaydeeumms's Avatar
Default skunk2 stage 2?
how do the skunk 2 stage 2 cams run in a b-16, wth a full valve job?
Valves, Retainers, Springs, Guides, and Timing Belt
Old Sep 9, 2005 | 07:08 AM
jamessh1's Avatar
Default Re: skunk2 stage 2? (jaydeeumms)
well, i'd ay with your current mods your torqueless monster should be good for ~175+ whp give or take with a good tune . Sounds like you've got a good set-up.
Old Sep 9, 2005 | 07:48 AM
ajreid's Avatar
skunk2 stage 2 needs compression.. I learned the hard way...
Old Sep 9, 2005 | 05:31 PM
jaydeeumms's Avatar
Default Re: (ajreid)
well i am getting a good tune... and i will have the compression... im getting a full valve job... skunk 2 valves, valve retainers, springs, valve guids, and a timing belt... dont worry, im doing this the right way... thanks guys.
Old Sep 9, 2005 | 06:45 PM
Yambor's Avatar
Default Re: (jaydeeumms)
how are you going to have "the compression" with only those mods?
tell me please
Old Sep 9, 2005 | 06:54 PM
99skunkedSi's Avatar
Default Re: (JH4DC4-2GSR)
you will need at least 11.5:1 with those cams!! i had them with a milled head (very little) and 2 layer h/g only got my c/r up to maybe 10.6:1 and i only dynoed 168whp and 108ftlbs with a few more mods than you. same car and motor by the way.
Old Sep 9, 2005 | 11:55 PM
Icey112's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JH4DC4-2GSR &raquo;</TD></TR><TR><TD CLASS="quote">how are you going to have "the compression" with only those mods?
tell me please</TD></TR></TABLE>if your not going to put pistons in it. your going to need flat top valves,one of the spoon head gaskets or just mill the head alot.
Old Sep 10, 2005 | 09:45 AM
BlkslowCRX's Avatar
Im running a stock JDM Gsr Bottom end completely stock. with just skunk 2 stage 2's valves and valve springs. Dont for get the Dc 4-1 header haha and my motor made 183 whp on a kenji chip in a p28 with a couple small changes on a vafc. Ill look around and see if i can find my dyno sheet
Old Sep 12, 2005 | 09:31 AM
jaydeeumms's Avatar
Default Re: (BlkslowCRX)
well is there a better set of cams i could get that wouldnt give me problems?
Old Sep 12, 2005 | 09:39 AM
flesh199's Avatar
skunk2 stage 1 -toda spec a-ctr/itr
these cam will be easy to tune with near stock compression ratio...
Old Sep 12, 2005 | 09:46 AM
jaydeeumms's Avatar
Default Re: (flesh199)
will i get any noticible power increases? and will they allow the engine to rev higher onc eig et all the supporting components?
sirt_eg
May 19, 2009 01:50 PM
msbhvn_DC2
Mar 8, 2006 08:11 PM
B16Anees
19
Oct 30, 2003 02:14 PM
10K2HVN
Jan 15, 2003 11:06 AM
Thrashin
Jun 26, 2002 07:33 AM
