cheap camber?
Old Sep 9, 2005 | 05:55 AM
psegs80's Avatar
Default cheap camber?
I dropped my 2000 civic coupe by 1"....do I have to get a camber kit and if so $$$$?
Old Sep 9, 2005 | 06:00 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: cheap camber? (psegs80)
Well on the rear it will cost you about $0.99 to fix it. Go to home depot and put a washer behind each bolt that holds the UCA to the frame.
You cannot adjust the front without a kit.
Old Sep 9, 2005 | 06:12 AM
nota-eg's Avatar
Default Re: cheap camber? (litterbox)
1" you don't have to worry much about camber wear.
Old Sep 9, 2005 | 06:50 AM
psegs80's Avatar
Default Re: cheap camber? (nota-eg)
I had some 17" rims with 40 tires and I was chopping the inside on the rear tires and almost nothing on the front ones...I just got some nippon f2 16" with Kumho 45...would the smaller tires have and added effect on camber angle being off????
Old Sep 9, 2005 | 06:52 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 &raquo;</TD></TR><TR><TD CLASS="quote">I dropped my 2000 civic coupe by 1"....do I have to get a camber kit and if so $$$$?</TD></TR></TABLE>
No; but you absolutely MUST get an alignment. I'm running almost 3* of neg camber with no uneven wear. Get your toe set to 0.
Old Sep 9, 2005 | 06:53 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 &raquo;</TD></TR><TR><TD CLASS="quote">I had some 17" rims with 40 tires and I was chopping the inside on the rear tires and almost nothing on the front ones...I just got some nippon f2 16" with Kumho 45...would the smaller tires have and added effect on camber angle being off????</TD></TR></TABLE>
Tires have nothing to do with your camber setting. With a larger sidewall, there is a bit more give, so the wear might not be as noticeable.
Camber does not wear tires, toe does.
Old Sep 9, 2005 | 06:54 AM
IHateJDM's Avatar
the angle is still the same. you may see a slight difference with a larger, more flexible side wall on your 45 series tires though (vs the 40 series). Make sure you get the car aligned when you lower it though, to correct the toe.
Damn autoxer, just barely beat me to it .
Modified by IHateJDM at 10:43 AM 9/9/2005
Old Sep 9, 2005 | 07:23 AM
psegs80's Avatar
Default Re: cheap camber? (IHateJDM)
will do so and actualy didn't know so!!!
2000 Civic 2dr coupe
98 jdm b181b (9.4 comp)
Ractive Cold air inatke
5zigen headers 4-2-1 custom collector 2 1/4"
magnaflow cat 2 1/4"
Custom 2 1/4" exhaust
Remus racing muffler
act stage 1
dc short throw
89MA70
Suspension & Brakes
Aug 11, 2008 01:01 PM
98savage
May 15, 2007 01:13 PM
evowu
Jan 23, 2004 09:02 PM
JReed
38
Nov 12, 2003 11:54 AM
BseriesMaddness
Feb 17, 2003 12:06 PM
