need help what size wheels on a EG h/b
should i go for the 15....or 16 i want to be low but not to low and dont want rubbing....but at the same time i want good brake clearence i have no clue post and let me know what you would say..pics are nice also
15 inch with a 195 50 series tire. Best combination for handling without too much of a sacrifice of the ride. Tires are less expensive too!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpr »</TD></TR><TR><TD CLASS="quote"> Tires are less expensive too!</TD></TR></TABLE>
i hear ya on that tirerack.com is the cheapest i found thats why i ride 15's
I would go with 15 and 205 tires!
I had 16 on my hatch and it rubbed like a bitch. Plus your car sits higher and if you dont have rolled fenders then they rub really bad!
I would go with a 16" rim...not too small, but not too big where you will see any power loss.
As for the tires...I would either go with a 205-40-16 or a 205-45-16...but if you go with the 45 series you may have to roll the fenders because it may rub.
if you plan on having any power then i would recomend atleast 205 for the tires other wise you will have trouble hooking up! I have 15 195/50 and LSD and i still cant hook up! But i also have a mildly built JDM Type R in a 2000 pound car!
15" on a hatchback (92-95) is absolutely hands down the nicest cleanest look and performs the best, wheels are lighter, tires are cheaper, have more wheel well clearance to lower it more if you want. it just flat out is the perfect size, 16's on an eg is pushing it, but still aight.
i have 16's on my 4 door and loving them, 205-40-16, haven't had any problems with rubbing yet and it's slammed like a mo fo
, id probably go 16 not to big not to small , it's what you like the best
how about no wheels
you can drive your car on hopes and dreams
because if you need help asking what size wheel you want, you shouldnt be driving.
its your car, not ours. it doesnt take that much common sense to figure out how much your car is lowered to figure out what size wheel/tire combo would fit.
my god just lock this thread
4DRmafia
Jan 31, 2006 05:01 PM
HATCHingMN
Sep 12, 2003 07:23 PM
