which tire size is better
Old Sep 8, 2005 | 07:55 PM
anomale's Avatar
Default which tire size is better for a 97
I have the stock rims and am debating between two tire sizes they are
205 45 16
or
225 45 16
list any advantages or disadvatages for either one
does anybody know the rim width 6" 6.5" etc...
thanks
Old Sep 8, 2005 | 08:14 PM
eMpAtHy's Avatar
Default Re: which tire size is better for a 97 (anomale)
niether will fit on a 6 or 6.5
you want a 7" for the 205 and 7.5 for the 225
Old Sep 8, 2005 | 08:41 PM
anomale's Avatar
Default Re: which tire size is better for a 97 (eMpAtHy)
I have the stock 97 rims and I wanted to know what the width of those rims is also which tire would look and or perform better on them
Old Sep 8, 2005 | 08:50 PM
MNsnowdaboy's Avatar
Free bump, I'm buying a set too this weekend....
Old Sep 8, 2005 | 09:08 PM
redlude503's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy &raquo;</TD></TR><TR><TD CLASS="quote">niether will fit on a 6 or 6.5
you want a 7" for the 205 and 7.5 for the 225</TD></TR></TABLE>
stock rims are 6.5" and stock size is 205/50/16, don't know why you said it wouldn't fit, even 225/45/16 will fit on stock 6.5" rims, its been done by alot of people. You won't see any performance gain over 205/50/16 because the tire sidewalls will bulge too much, but it will fit.
Old Sep 8, 2005 | 09:16 PM
anomale's Avatar
Default Re: which tire size is better for a 97 (redlude503)
I understand there will be no performance gain but will it look ugly with the 225's also if I lower the car will they rub the inside of the fender? the only reason for throwind out the 225/45 is because they will be a taller tire I am not sure if a 205/45 will be too low profile and look ugly also. Just searchin for opinions also the reason for going with the 45 serias is because I found a place that gets them for cheap 270 for a set of 4 "Z" rated
Old Sep 8, 2005 | 09:17 PM
DTPrelude's Avatar
after having a couple different sizes, i like 215/45/16. handles great, only problem is that its a hard to find size. i buy mine online.
Old Sep 8, 2005 | 09:40 PM
prelude1897's Avatar
Default Re: (DTPrelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DTPrelude &raquo;</TD></TR><TR><TD CLASS="quote">after having a couple different sizes, i like 215/45/16. handles great, only problem is that its a hard to find size. i buy mine online.</TD></TR></TABLE>
Thats the size I would get, but if not, then go with some P205/45R16 tires instead
Old Sep 8, 2005 | 11:30 PM
boostedlude97's Avatar
Default Re: (prelude1897)
i'm running 205-45's on my stockers for Auto-X and daily driving. looks great a lot less sidewall buldge than 205-50's and just a bit shorter. i personally wouldn't go with a 225-45 on a 6.5'' wheel, it just looks wrong
Old Sep 9, 2005 | 12:01 AM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anomale &raquo;</TD></TR><TR><TD CLASS="quote">I understand there will be no performance gain but will it look ugly with the 225's also if I lower the car will they rub the inside of the fender? the only reason for throwind out the 225/45 is because they will be a taller tire I am not sure if a 205/45 will be too low profile and look ugly also. Just searchin for opinions also the reason for going with the 45 serias is because I found a place that gets them for cheap 270 for a set of 4 "Z" rated</TD></TR></TABLE>
225/45 will look ok. it'll be heavier, cost more, and potentially wear funny, but they'll work--not as well as 225/45's on a 7 or 7.5" wheel...they're also stock diameter so the speedo will be accurate. they won't rub, though it depends on the drop.
205/45's a little short, imo--might look a little funny but you'll have better acceleration with the shortened gearing. speedo will be off by a few mph. handling will probably be close to the 225/45's if mounted on the stock rim.
either way, i think you'll be fine.
Old Sep 10, 2005 | 12:00 AM
Puppylaya247's Avatar
i have a 98 prlude which i recently bought 18" rims 225/40/18 stock was 205/50/16. I have a little tire rub going on the outside of the fenders i was wondering if it was possible to widen the fender or just change the suspension to coil over to stiffen it up. If you could give me a better suggestion i would really apriciate it if you could tell me.
Old Sep 10, 2005 | 08:48 AM
Lude454's Avatar
Default Re: which tire size is better for a 97 (Puppylaya247)
you can roll the fender but unless you are running 18*8 you don't need 225 go with a 215 or 205 that will fix your problem . or if you want a stifer ride buy some ajustable struts
Old Sep 10, 2005 | 10:19 AM
98vtec's Avatar
moderator emeritus
Default Re: which tire size is better for a 97 (Lude454)
i ran 225/45/16 on my stock wheels. The wearing was horrible on the inside of the tire. Even with an alignment, the tires still got ate up on the inside.
Old Sep 10, 2005 | 11:44 AM
UA6 BALLER STATUS's Avatar
Default Re: which tire size is better for a 97 (98vtec)
What tire width would best on a 16x7 wheel?
Old Sep 10, 2005 | 12:09 PM
98vtec's Avatar
moderator emeritus
Default Re: which tire size is better for a 97 (Type SH)
i'd run 215/45 to keep around the stock tire height.
Old Sep 10, 2005 | 04:44 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anomale &raquo;</TD></TR><TR><TD CLASS="quote">I have the stock rims and am debating between two tire sizes they are
205 45 16
or
225 45 16
thanks</TD></TR></TABLE>
Get back to work ricer
Old Sep 10, 2005 | 06:17 PM
maks's Avatar
Default Re: which tire size is better for a 97 (mkazm83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkazm83 &raquo;</TD></TR><TR><TD CLASS="quote">Get back to work ricer </TD></TR></TABLE>
mkaxm83:
It is better to keep one's mouth shut and be thought a fool than to open it and resolve all doubt. ~Abraham Lincoln
For the interested:
Honda Prelude Stock Wheel Weights
Car / Style Size Weight
93 Prelude VTEC 15X6.5 22.5
95-96 Prelude Si,VTEC 15X6.5 17
97 Prelude VTEC 16X6.5 19
97+ Prelude SH 16X6.5 19.5 - 39w/tires
Old Sep 10, 2005 | 08:33 PM
mkazm83's Avatar
Default Re: which tire size is better for a 97 (CluelessDrac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CluelessDrac &raquo;</TD></TR><TR><TD CLASS="quote">mkaxm83:
Geeee Sorry, I know him. Inside joke.
TurboHatchB16
Mar 4, 2009 07:55 PM
JSJ EG6
Mar 23, 2006 09:24 PM
SovXietday
Mar 22, 2006 09:16 PM
Greggie
Dec 29, 2005 11:13 AM
mugenintegra16
Sep 5, 2003 08:14 AM
