Battery Exploded - Need diagnostic help
Ok, I was driving home and I heard a crackling sound in my speakers which drowned out the music. I noticed it seemed to only happen when I rev it up. I stopped to look under the hood, and my battery is bulged out and puking acid all over the firewall.
I hook a battery tester up and find that it pegs it at over 14/15 volts.. I just replaced the alternator about 2 months ago because the voltage regulator was bad, so I'm wondering why it seems to be overcharging now.
Is there anything other than the alternator that could cause an overcharging condition?
Could be the alternator but also how hot has it been around your area? This is typical in area's like Vegas/Az/Texas 100+ degree weather areas.
The weather has actually been cooler than normal around here. I'm thinking something else has gotta be wrong if I need another alternator after just replacing it.
Has anyone tried putting a secondary voltage regulator inline to limit voltage? The alternator seems to be producing plenty of juice, and is almost brand new.
Update: I'm seeing 18v during idle measured at the battery. Anyone got info for a secondary voltage regulator I can use?
I don't really feel like ripping out my alternator again.
thanks
thanks
Most service manuals have you remove the axle to get the alternator out the bottom... that SUX!
I removed my steering fluid line, the strut tie bar, a few wires, and the upper alternator bracket... and the alternator could then be squeezed out the top. Took about 3 hours total.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapwr »</TD></TR><TR><TD CLASS="quote">Update: I'm seeing 18v during idle measured at the battery. Anyone got info for a secondary voltage regulator I can use?
thanks</TD></TR></TABLE>
Just replace the alternator... save yourself the headache... besides I don't think you can use an external regulator with the honda alternator which has a built-in regulator.
Yea, it's done. I bought the alternator from Advance Auto 4 months ago, so the replacement was free at least. The ELD circuit would have made a secondary reg tricky at best.
idewson
Aug 31, 2006 11:45 AM
BlowOff
Jun 11, 2002 07:08 PM
