weird surges when driving
Old Feb 26, 2002 | 09:00 PM
advan7's Avatar
Default weird surges when driving
Hey guys I just swapped a b17 into my rex, and am experiencing some intermittent surges when driving (doesn't matter which gear). When I'm driving and have the car at a constant speed, it'll feel like it'll sputter and then surge as if the fuel is cutting off for a brief second. It'll do this through all the gears, and was wondering if any of you have experienced the same problem. My current setup just to make things clearer is b17a1, type-r intake manifold and throttle body, skunk2 cams, gears, retainers and springs, and genuine spoon pr3 ecu all non-obd.
Thanks
Old Feb 26, 2002 | 09:06 PM
l's Avatar
l
Default Re: weird surges when driving (advan7)
plugs or plug wires?
my SHO did the same thing... i would be driving and feel the car pulsating and surging..... changed the plug wires and it made a great improvement...
Old Feb 26, 2002 | 09:12 PM
advan7's Avatar
hmmm i'll have to look into that, still using the wires that came w/it, but running new ngk plugs.
thanks
Old Feb 26, 2002 | 10:49 PM
AzG35's Avatar
It sounds as though your igniter might be going bad. They seem to go bad often in B series distributors. Might want to give it a check, maybe your coil too. Hard to say without looking at it though.
Old Feb 27, 2002 | 03:00 AM
rainforest's Avatar
Default Re: weird surges when driving (LSnoVTEC)
Also check the throttle position sensor it could b going bad. surges like that could men that it is no redaing the position of the buterfly on the throttle body.
Old Feb 27, 2002 | 04:55 PM
Quick 200k Mile Motor's Avatar
Default Re: weird surges when driving (rainforest)
*Bad O2 Signal (which could be a number of things).
can result in drivability problems in between 1k - 4k rpm
[Modified by Quick 200k Mile Motor, 1:58 AM 2/28/2002]
Old Feb 28, 2002 | 03:57 PM
iwhichisme's Avatar
you might also wanna check your map sensor, Ive heard a teg sensor works better w/ hybrid ef's. Im having the same problem and so is my freind, were just too damn lazy to replace the map sensor. try that along with the already mentioned remedies. ( a 90-93 teg)
peace
MUGEN_EG95
Jan 12, 2009 10:06 PM
sihonda
Mar 16, 2008 10:19 AM
utn
Jun 26, 2007 01:36 PM
VTC_CiViC
Nov 30, 2001 09:25 AM
integra7
Jul 30, 2001 06:41 AM
