ZC
Old Sep 8, 2005 | 02:39 PM
CRXsiproject's Avatar
Default ZC
I have a crx with a ZC engine but I dont now y it has a SOHC instead of DOHC?
Old Sep 8, 2005 | 02:42 PM
CRX Toad's Avatar
Default Re: ZC (CRXsiproject)
Um....I'm not really sure what you are asking. If it has one cam gear it is a SOHC if it has 2 cam gears it is a DOHC. Can you give us a pic?
Old Sep 8, 2005 | 02:46 PM
It has one but isnt supose to have 2 cams or is that a different zc
Old Sep 8, 2005 | 02:54 PM
CRX Toad's Avatar
Default Re: (CRXsiproject)
YES, there are two different version of the ZC. DOHC and SOHC as you have now found out.
Ass$nyper's Avatar
Pirate General...YARRRR
more then one ZC yours is the sohc zc
Old Sep 8, 2005 | 02:56 PM
so whats the difference in spec like hp and trq
Old Sep 8, 2005 | 02:58 PM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXsiproject &raquo;</TD></TR><TR><TD CLASS="quote">so whats the difference in spec like hp and trq</TD></TR></TABLE>This is where the search buttom comes in to play.
But I will be nice and spoon feed you. https://honda-tech.com/zerothread?id=1360901
Old Sep 8, 2005 | 03:14 PM
thx
Old Sep 8, 2005 | 03:18 PM
JKingCivicSi's Avatar
Default Re: (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">This is where the search buttom comes in to play.
But I will be nice and spoon feed you. https://honda-tech.com/zerothread?id=1360901</TD></TR></TABLE>There is a downside to that. You cannot search ZC.
Old Sep 8, 2005 | 03:19 PM
CRX Toad's Avatar
Default Re: (JKingCivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKingCivicSi &raquo;</TD></TR><TR><TD CLASS="quote">There is a downside to that. You cannot search ZC. </TD></TR></TABLE> Yup, that is correct, hence the link for him.
Old Sep 8, 2005 | 03:39 PM
Tyson's Avatar
ive found searching under "SOHC" is sufficient enough to find all the "SOHC ZC" threads.
but all you need to know is here.
http://www.norcalcrx.org/tyson/SOHC_Cam.html
Old Sep 8, 2005 | 06:13 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKingCivicSi &raquo;</TD></TR><TR><TD CLASS="quote">You cannot search ZC. </TD></TR></TABLE>
Maybe YOU can't...
http://www.google.com/search?s...2Ecom
Old Sep 9, 2005 | 03:56 PM
zccr-xsi's Avatar
cause the single cam zc is a vtec motor.whats your engine code?
Old Sep 9, 2005 | 04:31 PM
2kTeg's Avatar
Default Re: (vteckillenzc)
sohc zc isn't vtec sorry buddy its a stock crx si motor with a more agressive cam, shes a good little motor and carb legal replacement
Old Sep 9, 2005 | 04:41 PM
Idiotboy's Avatar
Default Re: (2kTeg)
Its a damn good motor, about 120 HP good for turbo aplications due to its relatively low compression and an easy swap into a CRX/EF. It'll be quick with some minor mods and a good driver.
Old Sep 9, 2005 | 05:11 PM
Kryogen's Avatar
Default Re: (Idiotboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">cause the single cam zc is a vtec motor.whats your engine code?</TD></TR></TABLE>
its stamped ZC, theyre all stamped ZC DOHC's and all versions of the SOHC ZC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kTeg &raquo;</TD></TR><TR><TD CLASS="quote">sohc zc isn't vtec sorry buddy its a stock crx si motor with a more agressive cam, shes a good little motor and carb legal replacement</TD></TR></TABLE>
The SOHC ZC comes in a lot of varieties, a pre-OBD 1.6L non-vtec (rated under 120hp), a OBD-1 version 1.6L non vtec and a OBD-1 SOHC vtec, and a OBD-2 non-vtec.
theyre descent motors, only a few HP off of the A6.
Old Sep 9, 2005 | 05:30 PM
APC4Life's Avatar
Default Re: (Kryogen)
Very good info Kryogen .... not many HT'er know too much about ZC's and unfortunately the search feature doesn't help due to the fact that ZC "Is too short or too common to be included in the search.
I too was once lost in the wierd ZC land my best advice is THE ZC RESOURCE http://www.thezcr.com
revikan
Feb 28, 2008 06:51 PM
bacnoonoi
21
Jan 31, 2007 07:18 PM
the king.
Sep 26, 2006 12:32 PM
fbapacible6
Sep 5, 2004 12:43 PM
crx88fast
17
Aug 7, 2003 04:53 PM
