Old Apr 1, 2015, 09:31 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Windshield Washer Nozzles
Old Sep 8, 2005 | 01:43 PM
mct121's Avatar
Default Windshield Washer Nozzles
The driver side nozzle on my 2000 Civic is partially clogged so I have to replace it. Is there a set of compatible nozzles out there that have a fan-out spray pattern rather than the two streams that came stock? I never liked this spray pattern and I hope to "upgrade" since I have to by new ones anyway.
BTW, anyone who suggests I get nozzles with lights has to buy them for me!
Thanks.
Old Sep 8, 2005 | 03:04 PM
Hapexamendios's Avatar
Default Re: Windshield Washer Nozzles (mct121)
id like to know also, i like the fan spray (maybe ones from a chevy metro will fit?
Old Sep 8, 2005 | 03:07 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mct121 &raquo;</TD></TR><TR><TD CLASS="quote">The driver side nozzle on my 2000 Civic is partially clogged so I have to replace it. </TD></TR></TABLE>
Just clean it out.
Old Sep 8, 2005 | 04:01 PM
distortedfuture's Avatar
Default Re: Windshield Washer Nozzles (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Just clean it out. </TD></TR></TABLE>
Old Sep 8, 2005 | 04:10 PM
dnoredsi's Avatar
Default Re: Windshield Washer Nozzles (distortedfuture)
rsx ones are that fan type nozzles but there mounted to the plastic trim just under the windshield . if u wanna customized a mount or flush them into the plastic. let us know how that goes. the only nozzle holes will have to be closed tho. so CF hoods don't have holes predrilled this would be an option.
Old Sep 12, 2005 | 08:32 AM
mct121's Avatar
From memory, I thought I remember hearing about accord nozzles working, but I don't know what model of accord.... Anyone else have an idea?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Just clean it out.</TD></TR></TABLE>
You are right, I don't have to replace it. If I can't find replacements with a fan pattern then I probably will just clean it out.
Thanks for the input!
Old Sep 12, 2005 | 08:43 AM
nahledge 7's Avatar
bump because ive been thinking about doing this for so long.
Old Sep 12, 2005 | 08:47 AM
pdiggitydogg's Avatar
ep3 are fan...I have them on my car
I'll tell you, theyre not that great. If I could, Id go back to the jets.
The reason I say so, is becaues the stream is very weak. When driving down the highway, they only shoot about 1/3 as high (at a stop they hit where they should).
Pop off your plugged ones and clean them...
Old Sep 12, 2005 | 11:05 AM
nahledge 7's Avatar
thanks for the look outpdiggity
Old Sep 12, 2005 | 11:25 AM
crazy eyez killa
Guest
Posts: n/a
Default Re: (nahledge 7)
ditch the clogged one.
reroute the hoses and nozzle into your grille so it sprays forwards. Make sure to only use one nozzle (lose the Y connector) so you have twice the spray. You can now dirty peoples cars in traffic when they cut you off.
i did this years ago on my 97 DX hatch and it was fun.
Old Sep 12, 2005 | 01:12 PM
mct121's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">ep3 are fan...I have them on my car
Pop off your plugged ones and clean them...</TD></TR></TABLE>
Good info to know. I think I am keeping the jets. Thanks again to all the contributors.
mike
Old Sep 12, 2005 | 01:27 PM
SirRevvs's Avatar
Default Re: (mct121)
Numba 1 stunna says get the led washers from autozone, they be tight y0!
J/K I'm curious to know of some better spraying aftermarket nozzles as well.
Old Sep 13, 2005 | 12:10 PM
mct121's Avatar
Default Re: (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">Numba 1 stunna says get the led washers from autozone, they be tight y0!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mct121 &raquo;</TD></TR><TR><TD CLASS="quote">BTW, anyone who suggests I get nozzles with lights has to buy them for me!</TD></TR></TABLE>
I knew I would get someone to buy me a set!!
Old Sep 13, 2005 | 12:20 PM
Sijray21's Avatar
ok i've seen posts of cleaning them...i'd like to know how and with what? I don't want input from people who haven't done it or who don't really have a clue...it won't help if someone screws up their washer b/c you wanted to "try" something.
i know the accords of the previous gen (2001 to whatever year) have the spray washers, i like them alot.
Old Sep 13, 2005 | 12:28 PM
just dunk them in solvent for awhile
anything to break whatever it is (prob wax) up
Old Sep 13, 2005 | 01:30 PM
Chiovnidca's Avatar
Default Re: (Sijray21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 &raquo;</TD></TR><TR><TD CLASS="quote">ok i've seen posts of cleaning them...i'd like to know how and with what? I don't want input from people who haven't done it or who don't really have a clue...it won't help if someone screws up their washer b/c you wanted to "try" something.
I remove em from the car, poke them out with a thin piece of wire then blow them out with compressed air. The newer style I just use compressed air on.
Old Sep 13, 2005 | 03:12 PM
C2daIzZle's Avatar
i use pin needles to clean poke at the holes for a minute, go to your car squirt squirt, then poke some more (:
Old Sep 13, 2005 | 06:55 PM
civic_driver's Avatar
i was gonna say that.. clean them with a needle or something tiny and sharp...
tigueremalo
Oct 9, 2007 02:39 PM
Nocturnal
14
Jun 9, 2007 06:19 PM
localev
Jan 22, 2006 05:44 PM
94HatchbackSI
Honda S2000
Nov 9, 2004 01:34 PM
