need help removing header and cat
Old Feb 26, 2002 | 08:32 PM
SamC's Avatar
Default need help removing header and cat
I've been reading about how to remove/install the header...I know the procedure...in fact, I was just working under my car....My question is...is there a easier way to take those bolts out...is been a bitch trying to take the bolts off the cat. Do I need any special tools? any help would be appreciate...thanks
Old Feb 27, 2002 | 12:54 AM
dirtySOHC's's Avatar
Default Re: need help removing header and cat (itr195hp)
airguns work wonders
Old Feb 27, 2002 | 03:51 AM
Geezer's Avatar
Go out the day before working on the car and hit all the nuts on the exhaust with a good penetrating spray. I use CRC Power Lube, but others will probebly work as well.
Old Feb 27, 2002 | 05:41 PM
GTM's Avatar
GTM
Default Re: need help removing header and cat (SamC)
The easiest (and safest) way to take exhaust bolts out are by heating them up with a propane torch available at any hardware store. NEVER simply use and airgun. They can break old rusted bolts and then you will spend a lot of time trying to get them out.
Old Feb 27, 2002 | 08:22 PM
chillly's Avatar
Default Re: need help removing header and cat (GTM)
I agree with the heat. I just found the nifty-est (is that a word?) little gizmo at Home Depot. It converts a cigarette lighter with the flint removed into a small torch. Small size makes it easy to get to otherwise hard to reach bolts. Besides, I'm too poor for a propane torch.
Old Feb 28, 2002 | 07:37 AM
StyleTEG's Avatar
Default Re: need help removing header and cat (uncivilCivicinprogress)
I went and got replacement nuts/springs assembly for the cat the day before, then carefully sawed the old ones off. Worked out really well.
Acidcrakker
Mar 3, 2008 08:46 PM
MilanoLude
May 18, 2007 04:30 AM
GSRerrr
Mar 4, 2005 08:50 PM
94B18B1Teg
Mar 15, 2004 11:05 AM
NSX Bob
Oct 17, 2001 03:55 PM
