FS: Coolingmist water/alcohol injection kit
Parts I have:
Deluxe Single Stage kit: http://www.coolingmist.com/detailpage.aspx?pid=02
2.5 quart water tank: http://www.coolingmist.com/det...=1402
in-line water filter: http://www.coolingmist.com/detailpage.aspx?pid=12
90 degree nozzle adapter: http://www.coolingmist.com/detailpage.aspx?pid=047
flow/clogged nozzle detector: http://www.coolingmist.com/detailpage.aspx?pid=05 (looks like they have a brass one now, the one I have is not brass, and ran $40)
150 PSI pump switch upgrade: $40
The nozzle is a 2.3 GPH @ 100 psi nozzle. Other sizes are available from Coolingmist for $10. This kit has a 1-4 PSI boost switch, higher pressure switches are available from Coolingmist. I have leftover hose tubing from the kit. The kit can utilize water, water/alcohol mix, or straight alcohol.
$360 worth of parts, used about 400 miles.
$250 plus shipping.
Modified by sharkcohen at 8:40 PM 9/12/2005
$250 plus shipping.
sharkcohen
Northern California (Sales)
May 13, 2007 03:16 AM
