complete b18 .... $250... broken mount bolts on block -- fixable?
Old Sep 8, 2005 | 11:55 AM
2fast4udude's Avatar
Default complete b18 .... $250... broken mount bolts on block -- fixable?
not a forsale thread
i found a junkyard in town with a complete b18 engine they want $250 for... apparently it runs fine and all that jazz, was pulled from a wreck. the problem is, the wreck it was in busted the mounts on the block.. where the engine mounts screw into the motor, the thread holes are broken on the side walls of the threadding.. i dont know if that makes any sense.
anyway, i was just wondering if its worth it, is this fixable? thanks guys
Old Sep 8, 2005 | 12:04 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: complete b18 .... $250... broken mount bolts on block -- fixable? (2fast4udude)
depending on how bad the impact/damage is, you may have problems with the #1 cyl sealing and also the hradgasket. Call a few machine shops and see what they will charge you for repair.
THE M4CHIN3
Jun 24, 2013 09:53 AM
ProjectEvilEj2
Dec 25, 2012 09:57 AM
fv8s
Feb 18, 2010 02:19 PM
teamitr
Nov 17, 2005 07:09 PM
O16581724 5 2 5
Oct 1, 2005 05:57 PM
